Sam,
I've seen it on both sides. Outside of ring if boot is torn, inside if fluid not changed.
proskeeterman,
If you change the brake fluid regularly and the boots aren't torn and they work properly, you shouldn't have to rebuild them. The one I recently replaced was my own fault-brake fluid looked like burned trnny fluid.
'94 3500 4x4, 210,000 miles, Never had a cat, Auto w/shift kit (thanks Dave G), 3. 54 Gears, TST #5 plate, 235-85-16s, Rancho 9000s w/remote, Isspro Gauges & Amsoil Air, Oil & Bypass Filters & Lubes, AWOL intake boot.
Punchlist: 14 cm Turbo Housing & 215 Injectors.
NRA member.
Blue Ribbon Coalition member.
"I am my own performance station"
proskeeterman,
NRA member.
