Have you made sure that you greased the slide areas of the calipers and the pins/bolts? Another thing to check is the rear brakes, make sure they are adjusted good. I replaced both calipers and my brakes would pull slightly but once the pads seated in the problem went away. Last of all, make sure the tire pressure is even on both sides and the only other thing could be if you alignment is way out.
