Brand new 2020 won’t start
Injector? Very high temp suddenly
2006 2500 stuck in park
Yes to the fob. Drivers batt 11.5 passenger 19.5 will charge over night and check um in the am suspect the passenger side is tango uniform
If you see such a difference then there is something badly wrong.
They are wired in parallel and therefore should ALWAYS show the same voltage.
You are in for trip to the dealer to examine why your truck drains the system.
50ft is by far enough distance to set the system to sleep, @sag2 could tell us how far the near field communication works around the truck.
People sometimes mix that up with the normal range of the remote but that are two different systems.
Simple homemade test, set your FOB on the ground 3 yard away from the vehicle and try to open a door, shouldn't work.
