Would like to know if anyone else has had a problem with the (as the dealer calls it) the kick down lever, breaking, in a 1999 Dodge automatic transmission? Tanny wont leave first gear unless you let up on accelerator pedal. Transmission has a H. D. torque convertor and valve body installed. This is second time this part has failed in the last three years and the transmission must be removed to install a new one. The dealer says these never break and cannot figure out what is causing them to break. Anyone had the same problem? transmission works great otherwise.
