I am hoping to get good news to make me feel better after my findings.
I own a 2002 Dodge ram 3500 quad cab, automatic trans. I had a little over heating the other day on my 24 valve 5. 9 cummins. When I got home after driving it about 2 miles. It never reached the red mark but it did get close. Once I stopped and parked it was leaking water badly. I looked at the water pump and the pulling wheel was all wobbled out. I knew this meant the bearings were gone. I just had the water pump replace by a garage 2 years ago too.
I pulled the water pump off to find 3 of the blades were totally gone. The other two bent over. I felt around the opening of the hole where the water pump mounts and found two blades laying in a small channel.
This is where it gets bad. I was able to get one. The other after trying to getting it out using my pinky finger, trying to move it up along the channel. It fell into a hole just to the right of the opening behind the fan housing. The 3rd blade hasn't been seen at all.
Please don't tell me I have to tear down the engine. Unless you have too. lol
Please tell me what is needed to fix this problem. I am not a mechanic, but I have worked on many under a few trees. This is my first diesel.
I'm hoping this is a simple flushing since I read that broken blades on water pumps can be a common problem. thank you
