J. Davy said:What is the purpose of the flex plate? If I change it to a stronger one will I compromise something else?
robertyoke said:the reactor/dtt flex plt is more like 500 bucks not 700. piers sells a heavy steel for under 200.
Don't make the mistake I made, put in the ats tc then couple thousand miles later I did the reactor flex plt and billet input, that's one more time of pulling the trans and puting it back in, do I all at once if you can swing it.
J. Davy said:I only hve 2200 km on the truck. Its a little discouraging that they can break that easy. Who makes a better one?And what are they worth?
