Let me say first off that I had second thoughts about running a propane system. I was scared I was going to blow up myself & the truck.
Now that I look back, It was silly. I felt better when my propane guy that filled my tank dissappeared into a fog of Vapor when he filled the tank. There must have been more propane in the air than in the tank
Installing the regulator/Soleniod was straight forward. Mounted it just to the rear of the left side battery. I needed to drill a 3/4" hole in the bottom corner of the bed for the gas line.
Ran the line along the frame inside a "wear guard". Attached with long heavyduty tie wraps. Where the line goes thru the bed got a piece of 3/4" rubber hose as an added measure to prevent chaffing. I will keep an eye on this.
Attaching the injection to the intake duct was easy too. Had a 3/4" hole saw. Just follow directions and its a breeze.
Wiring simple & straight forward.
I mounted the Hobbs pressure switch in the 3/4" pipe plug on the intake manifold just to the rear of the intake temp sensor. Needed a 3/4" to 1/8" reducer. There is a lot more room there as opposed to the side of the manifold, where most of us have our fitting for the boost gauge screwed in.
Finding a P. O. L fitting to screw into an ACME valve on 20# DOT (BBQ) tank was a pain. Home Dummies and hardware stores don`t have them without a regulator attached to them. Most have just a pinhole to allow propane to flow. This won`t work with this system. Went to an RV store and found a P. O. L fitting. It is an "excess" flow POL. If the gas surges, it has a check valve that will limit the flow. So far it seems to be ok. I would have rather got the "full flow" POL valve (straight thru), but they were not in stock. First I went to the local propane shop. Long story short, the guy wouldn`t help me. He showed me a company truck that had a big 100 gal tank in the bed. I made the mistake of showing him my gas line in the bed. I also should have said its a vapor system , intermitent and for "off road" use. Apparently he thought it was a liguid system. I didn`t feel like arguing . Waste of time.
To attach the POL to the Bullydog line required a 3/8" flare to a 1/4" reducer, and and a 3/8 male NPT to a 3/8 flare male union.
Bought the "yellow" thread tape especially for LP. Checked all fittings with soapy water. Had a minor leak, just tightened the fitting a little more.
Adjustment of the regulator was easy. Put a jumper on the Hobbs pressure switch to override it. Adjusted as per the directions. I could not get any knocking or pre-detonation. (good) I adjusted it until the engine would shake and miss. Then backed screw out 1 1/2 turns. This is the "performance" setting. 3-4 turns out is the "street" setting.
Apparently propane has no benefit to an engine thats just at idle. There is just not enough fuel. (Idle= 99% air,1% diesel)
The Hobbs pressure came pre-set to activate @ 7lbs boost. It is adjustable. I tried to adjust it to open at about 2-3 lbs boost. Took for a test drive. Saw that switch was activating at idle. I thought there would be a big "loadup" of propane in the intercooler while idleing. Not the case at all. Engine ran as normal. Flow was at the "performance" level too. When I was adjusting the regulator, I noticed that the engine reacted to the adjustment very quickly. The intake air is moving faster thru the intercooler, even at 0 lbs. boost than I had previously thought. Hence no "loadup".
Its kind of tough to hear the seloniod opening. letting the propane flow. What I did was attach the hot wire of a little light bulb to the seloind and to a good ground. I attached the bulb to my windshield wiper. Now I can see when the switch has activated. Much eaiser to set the pressure switch now.
I have run the system for an hour so far. Have not even mashed the loud pedal yet. With the price of diesel going up, this ought to pay for itself in a couple of years. 3-4 MPG increase should be average.
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust,Autometer Pyro & Boost gauges, Bosch 215HP injectors, Timing @ 14. 7 BTDC, JRE Stage III #4 plate 270/675, AFC spring kit,Pschotty Air, Optima Red Tops, Geno`s Exhaust Blanket, Synthetic lubes throughout.
[This message has been edited by HEMI®Dart (edited 09-12-2000). ]
