Is there any way the dealer could tell if you installed this cam if you were able to do the install without cutting and welding the crossmember?<!-- google_ad_section_end --><!-- google_ad_section_end --><!-- / message --><!-- sig -->
How will the use of this cam affect performance modules or downloaders that advance the timing? Will it be advanced in addition to what the cam added or is it based on something else?
There would be the mechanical advance from the cam and the electronic advance from the injectors. Correct?<!-- google_ad_section_end --><!-- google_ad_section_end --><!-- / message --><!-- sig -->
