Camper wiring
Mud Flaps
Too much trailer for a 2500?
tried the search, came up empty... .
I need a wiring schematic for a lance camper... just what wire goes where on the seven pin plug. :(
I've been told that the slide-in 7 pin connector is wired quite differently than the standard RV connector. My brother has one (not a Lance) and the center conductor is 12V hot.
There's nothing at http://www.lancecamper.com about the wiring unfortunately. Might be a good place to start, though.
With the plug slot up, looking at the plug on the camper:
the 1 o'clock pin is open
the 3 o'clock pin is right turn and stop - Brown - 16 gauge
the 5 o'clock pin is left turn and stop - red- 16 gauge
the 7 o'clock pin is 12 volt power - black - 8 gauge
the 9 o'clock pin is back up lights - yellow - 16 gauge
the 11 o'clock pin is running lights - green - 14 gauge
Center pin is ground - white
Hopes this helps
Thank you Rob!! She's a beaut! White w/ blk & grey trim. ATClark, thanks. You're a life saver. Here in Post Falls now with the camper on. Will do a quick wire job to get me home, then wire in something more permanent later. Didn't plan on buying one today, but had to when they actually accepted the offer. Told them to throw in a torque lift at no extra charge and they agreed reluctantly. 1998 Lance 9'10" ... . very nice camper. Air bags next :)
