Can a stock ETC 5 speed squeal the tires?
fuel filter problems
Wholly TC ~ VB Batman I'm Gonna Get Arrested
Hi,
I have a stock ETC with a 5 speed. From a dead stop if I let the clutch out at idle and stomp the gas the tires do not squeal. If I do the same in second gear I have no squeal. If I take off hard in second while turning a corner they lightly twist.
Is this normal?
I remember test driving an automatic a few years back and it would light them up if the go petal was on the floor. I did not remember if the auto had LSD and 4. 10 gears...
If my truck is weak due to a junk lift pump I will see what pressure readings when I get my gauges installed in the next 30 days...
2001. 5 QC 2500 White Sport 4x4 LWB ETC 5-Speed Anti-Spin 3. 54 Trailer Tow 241HD SLT+ Tan Leather(Mad Cow Disease) LT265/75R16E ARE Z Series Cap Bedrug ICI Nerfbars
Your limited slip diff. is working. maybe the one you test drove did not have limited slip. I have an auto and even with some mods it wont spin them. it just takes off #ad
at least I cant hear them spin but if I look in the rear view there are two black strips hehand me. . Its does not roast them but it does pull hard. .
2001. 5 2500 4X4, QC, Auto, 3. 54 LSD, SLT, SWB, Trailer, Camper & Snow plow Packages, White, 35k# Cody Hitch, 20' Gooseneck Lowboy flat-bed Trailer.
1975 Toyota Landcruiser, ARB Air lockers Front & rear, 400 Small Block, SM420 4spd, Stock LC transfer case with 2 or 4 high and 2 or 4 wheel drive Low gears, 15. 5x36" Radial swamper on 12" rims, Custom front & rear bumpers, Roll Cage, Warn 8274 8000# winch, 2. 5" spring lift, 2" body lift. Premier on-board power welder, on-board air, 4-wheel power disk breaks, power steering, Lot of fun.
TomC,
Going to Poteau for Memorial Day?
Charles
2000 QC 2500 4x4 LWB ETC/DEE, Anti-Spin, 3. 54, Trailer Tow, Camper Special, DD1's, PS boost module, PS high idle kit, PS steel idler pulley, Autometer boost and EGT gauges, Westin nerf bars, Rhino Liner
My Toy
1969 Toyota Land Cruiser FJ40
350 TBI, Turbo 400, ARB lockers front/rear, 4 wheel power disk brakes, 4. 88 ring/pinion, 3 speed transfer case, full roll cage, Warn 8274, MRT 36 bolt beadlocks with Super Swamper Boggers (16x35x15), Saginaw Power steering, custom bumpers/fenders/nerf bars/skid plate, GM tilt steering column, 6 point roll cage, RCI racing seats with 5 point harness. Loves to be pulled behind the Dodge and pass the powerjokes going up hills.
you bet. I'll be (lets say) burning rubber to get there. I finally got my piro meter in (pre-turbo). wow do those temps change fast. It will be interesting to see what they get too towning over the mountains. how bout you charles?? going to poteu?
PS the moab pictures look nice #ad
I'll get there some day. .
[This message has been edited by Tom C (edited 05-13-2001). ]
Joe,
What you are experiencing is normal. By simply mashing the throttle in 1st or 2nd you aren't going to peel out in a straight line with stock power.
The automatic had a couple things going for it to peel out: the trans puts a bigger load on the engine (builds boost faster) and you don't run out of gear as fast as a stick.
Now if you want to do a burn out,you'll have to 'lightly' power brake it (you'll have to practice your right foot 'heel-toe' action) while dumping the clutch in 2nd gear. #ad
-Mike
Something doesn't seem right here. I have a 3500 ETH and can leave 4 nice stripes. Granted it's easier with the EZ but quite capable stock too. Actualy the EZ made traction my biggest problem when empty. I had kind of wondered how you SRW guys could keep tires on your trucks.
Don't ask, least this way can try out lots of different tires #ad
With the Dueler 285's they don't squel anymore, but can still leave layers of black on the street ... .
One question;
Why would you even want to? That ain't what the truck's for. If it don't, be happy. It works like it should.
Preston
96 3500, Black SLT, 5 speed, turbo diesel, , with US Gear overdrive, Rhino liner, Reese 15,000 lb. fifth wheel hitch, US Gear de-celarator exhaust brake, muffler elimination kit, Amsoil lub. , Mag-hytec rear cover, dual-remote by-pass filters, and Roadmaster Active system, AutoMeter Pyro & boost, Primeloc
If you guys want to see Cummins/Dodges doing smokey burnouts, just show up at Brice Road in Reynoldsburg Ohio--(just East of Columbus) this weekend in the evenings. Us drag racers can't get enough burnouts at the track!!! Its COOL to watch a Dually smokim' off! #ad
Y2K Black 3500 4x4 SLT+ Leather ETC/DGA DMF/DSA Luverne SST Bars
'64 Plymouth 426 III (Max Wedge)
'79 Chrysler 300 T-Tops NRA Member
Try this, give it some pedal, (maybe 1500-1800 RMP) let the clutch out quick as you role on the fuel, then stomp and hold the brake pedal, if it don't smoke then, either you just adjusted your rear brakes, or there is something wrong.
Mine will not smoke the tires, but it has gone sideways on the highway a couple times, in the rain, in 4th gear, WOT, passing somebody, just when the turbo spools up. kind of scary when it happins!
TomC,
Yes, I'll be at Poteau. My pryo reacts very quickly. You'll be surprised how fast you can get it up to 1300 degrees while towing. I had to watch mine most of the time when I was towing through New Mexico and Colorado because it just wanted to pull.
Charles
My Toy
I test drove an ETC 3500 with 5 speed back in February before I bought my new truck. The saleman drove it first while I rode, and he decided to show it off. From a stop sign, he could squall them all the way to fourth gear.
My new truck is a 3500 ETH with 6-speedand limited slip. It's still stock, but it'll torch the tires from a standstill, all the way to fifth gear #ad
Just rev it up to about 2200 and dump the clutch. YEEHAW! #ad
2001. 5 3500 4x4 ETH/DEE 3. 54 LSD, HD transfer Case -- Quad Cab, Patriot Blue, Everything but leather #ad
, modified 6-way turn signal conversion (thanks Evan), K&N,
Real back-up lights, muffler and res. got knocked off in an off-roading incident (he he).
What silencer ring? #ad
Forget warranty -- BOMBS AWAY! #ad
[This message has been edited by Gizmo 007 (edited 05-14-2001). ]
That must be it. I really am quite happy with the power. I know the truck is not a drag car. I just do not want to be stuck with a problem that should have been solved. I feel bad going down to the dealer to drive the new trucks they have just to compare them to mine...
FWIW after I ordered my truck the dealer ordered two CTD's for the lot to keep in stock. With the price of fuel these days they should sell them soon.
Someday it will get BOMBed...
smokin joe:
my 99 3500 would not spin the tires until i added some minor mods. after i had the DTT TC and VB installed,my auto will light up all fours through third!!!its impressive. only downfall, tires don't grow on trees..... james...
1999 RED LOADED 3500 QC DUALLY. 331N. DUNLOPS,ALPINE AUDIO,PSYCHOTTY AIR WITH K&N,BANKS POWERPACK,275 injectors, VA CPC, soon come. . DTT TC and VB. more in store????
My 2000 is all-stock right this minute, and won't even chirp the tires going straight if I stand on the throttle. If I'm turning, I can get a little bit of squeal, but I think that's the LSD torquing up one wheel more than the other. #ad
I'm hoping with the DDII injectors, boost module, and boost elbow, that I can at least get a little bit of rubber laid down from a stop.
Greg
Y2K Dodge Cummins QC 2500 SLT Laramie 4x4 Long Bed, 4. 10/Auto, Forest Green/Driftwood, 265x75R16 Michelin LTX, 6 speaker CD, Camper/Tow/Plow Packages, Westin Black Nerfs, Mopar bedliner, Ultra bright diamondplate toolbox, K&N Filtercharger. Autometer EGT and Boost gauges with 2-gauge pillar coming soon!
http://www.rints.com/hammond for photos!
Tom C and Fj40Charles, you guys are going to Poteau? I have not been there yet, but would like too. As I don't know my way around that area the closest I have been to there is Clayton, Ok which is really fun. I am trying to think of a trip to go on, but I thought I would go to Yellowstone would be cool, but I think four-wheeling would be far better. What days are you going to be down there? Are you four-wheeling with a large group as I think if you guys don't mind I may go as well.
2001 2500HD Quad Cab SLT SB 4x4, HO Cummins, 6-speed, 3. 55 gears, LSD, brightwhite/driftwood, 4w ABS, camper and trailer tow packages, HD transfer case, snow plow prep, group, cab lights, Isspro Boost and Pyrometer gauges mounted on A-pillar, 4" JRE exhaust, BD exhaust brake, SW fuel pressure gauge. 30,000 miles and counting as of 2/28/01.
1980 CJ-5, Modified for off-road use, bobbed fenders, 350 TBI, NP435 trans, 4. 56 gears, Dana 300, Dana 44 front, Dana 60 reverse-cut rear axle, ARB air lockers front and rear, 15/35/15 Super Swamper TSL on 10X15 steel rims, Cobra CB, Warn 9000I winch, nerf bars, 1/4" steel rock crawler bumper front and rear, jerri can/spare tire rack, custom roll cage.
My Webpage: www.homestead.com/dhatfield2/trucks3.html
