Can engine vibrations destroy an Air compressor?
E Brake question
1998 2500 on Ebay in Nebraska
I may have found an after market company doing direct engine bolt on air compressors. I can't believe how much violent shaking happens when the Mighty Cummins is shut down. This shaking looks like it could easily destroy most bolt on engine accessories. This is especially true of a product that may work fine on a gasoline powered application.
What do you guys think? Is there a compressor out there already?
2001. 5 QC 2500 White Sport 4x4 LWB ETC 5-Speed Anti-Spin 3. 54 Trailer Tow 241HD SLT+ Tan Leather(Mad Cow Disease) LT265/75R16E ARE Z Series Cap Bedrug ICI Nerfbars
Tractor trailer engines use a direct bolt on/gear driven compressor unless they've changed. Those things run forever. I'm surprised Cummins doesn't have one for the B5. 9.
Cummins does have an air compressor for the "B" engine. It mounts where our vacuum and p/steering pumps are. In this application the p/s pump mounts to the rear of the air compressor and has a separate reservior. Ford then uses an electric vacuum pump to supply vacuum for the a/c controls.
01. 5 QC ETH/DEE 4X4 LB intense blue sport, everything but leather and cab lights. Trailer and Camper Packages. DC brush guard, missing turbo ring, amber rear turn signals and real back-up lights, K&N re-0880
Where can I find one of these air compressors? I've looked but all I can find are electric models. I like the belt drive model better.
TIA
2001. 5 3500 4x4 ETH/DEE 3. 54 LSD, HD transfer Case -- Quad Cab, Patriot Blue, Everything but leather #ad
, modified 6-way turn signal conversion (thanks Evan), K&N, 275's, PS boost module,
Real back-up lights, muffler and res. got knocked off in an off-roading incident (he he).
What silencer ring? #ad
Forget warranty -- BOMBS AWAY! #ad
[This message has been edited by Gizmo 007 (edited 05-16-2001). ]
It may be that onbaord air(http://www.onboardair.com/) has one for our RAM soon. Belt driven.
