I have a bad rear bearing in the OD housing. I have the trans on the bench, and it is obvious, a rattle grind in the back half.
Can I just remove the tail housing (OD hosing) from the front, main case to service that bearing?
We removed the small cover on top, spread apart the Snap ring, and have been working it apart a bit, but I think I am missing something, or it is bad stuck.....
I do see I must pull the pan to loosen the park rod.
The trans is a "fresh" rebuild, but obviously he missed something in the OD housing!
