Wiredawg, Will Alfa work on 2018, nukegm you will also need the bypass module, the location is behind Radio 2018 Ram Classic, You will also need to remove it for factory WITECH, it will work Running.
Recommend you check out the website for compatibility. You might need an unlock cable. But the tool is cool and you get some pretty powerful options for lots of factory configurations. I purchased everything on Amazon.
Cheers, Ron
Indeed......a lot of 2018 HD owners over on CF have used AlfaOBD for quite some time.AlfaOBD has worked fine on my 18. I use the M2 unlock cable with a MX+.
hey comrade tcdiesel - i think i will follow your advice. im not that good at computer stuff. nor do i have the time. do you prefer any sensor over another? THANKS much. cheers, chris and thanks everyone else for your input. it is appreciated.IMO , just spend the $40.00 on the sensors and install, and drive , the TPMS module will pick up the new sensors... Now the Ugly part changing the Tire pressures in the module.
THANKS TC. will order now. slid down a ice covered hill at 6 am today and went from 5mph to 45 with the brakes on the entire time. more motivation for some studded duratracks.... thanks again. chrisOEM ONLY. Part # 68249197AA This place has them for $39.09
https://parts.moparonlineparts.com/oem-parts/mopar-mopar-tire-pressure-sensor-68249197aa/?c=Zz1lbGVjdHJpY2FsJnM9dGlyZS1wcmVzc3VyZS1tb25pdG9yLWNvbXBvbmVudHMmaT1UTTEzMjcwNSZyPTEmYT1yYW0mbz0yNTAwJnk9MjAxOCZ0PWxpbWl0ZWQmZT02LTdsLWw2LWRpZXNlbA%3D%3D
