CAN I USE ATF IN THE POWER STEERING PUMP?
Bye Bye Silencer Ring on new truck
Mirrors trade
I would like to change the power steering pump fluid(STEERING FEEL'S HEAVY WHEN COLD) & I have a gallon of AMSOIL ATF+4. I know most GM use ATF but my manual say's to only use the mopar fluid. I put this stuff in my trans and it shifts much better when cold and by the way the old fluid & filter looked new.
95 CUMMINS W/AMSIOL 5W-30 CC 2WD AUTO W/AMSOIL ATF+4 +GENO'S COMBO GAUGE + SONY 10 disc + 1 CHAMBER FLOWMASTER +LOST cat + silencer ring + slid stock plate & k&N so far... ! member of the SETDR
[This message has been edited by cumminsturbo95 (edited 01-28-2001). ]
Some folks use Amsoil ATF in their PS,but it's not rated for it nor recommended by Dodge. Use Valvoline sny PS fluid,works better than Mopar PS fluid in cold weather.
I wouldn't use ATF in the power steering system. It would probably work fine, but it could cause the seals to start leaking. Nothing worse than leaks.
Hery Hickster,
I would not do it because transmission fluid has been known to play havic on seals. It can and will make you pay for a pump in the future.
Scary
Hery Hickster,
Scary
