Can you disable tire pressure monitor??
Which axle do I have?
Installing Edge Insight 2008 Ram 3500 Removing dash side panel
My dad has an 08 Dually. If I use his vin# , you think I could recalibrate it with a scan tool at the dealer??
Or could I attatch the valve stem sensors to the existing valve stems like an extension?
Thanks guys!
Garry
08 Dodge 2500 :rolleyes:
Alright, Install sensors, mount and balance,Now if customer wants Lower/Higher Pressure in front/rear, Mark accordingly, Place all 4 tires in correct location Make sure the spare if equip is set at the Lower Pressure,Make sure you Tag the spare for the Pressure installed, that way you will be able to increase/decrease if necessary when used (May need to set if used in location Pressure Not set If used). Set Vehicle in learn Mode, Place tool next to each senor until vehicle recognizes New Pressure,(one @ a time)Horn, lights,radio,etc, each make and model has different indications,Nissan and a couple other Makers require factory tool, I cannot say it will work on 2008 6. 7 ( as soon as one comes in for upgrade or change I will know for sure) ,But works on all 2007 Rams equip with TPMS. Huge fines if removed for on road use. (IF CHARGED).
