I have this exact set up, carli springs, and the bilsteins, front and rear. I initially went with the cheaper set up, carli front springs and shocks only. This leveled out the rig, but ended up with at negative rake, by 1” truck always looked like she was sagging, and I ****** off on-coming drivers with the headlights. Bought the rear spring pack but before I had the springs installed, I did the shocks. WHAT A DIFFERENCE!!!! just the shocks made. The spring pack leveled out the truck and now it looks like it should. As for feel, I have had people comment that it's like we are just floating over the bumps. With no load, she's a tight ride, but wait... it's a truck... duh! Add a few pounds, like my little 5k travel trailer, hardly feel anything. Suspension eats up the bumps, and you don't feel them. I think the truck handles well... much better on and off road. There is a famous spot on the freeway where you washboard on a curve. After the suspension install, not anymore. Off road, you are in full control, I'm very impressed. I feel tire and tire pressure play a critical role with handling and feel. I'm going to try to ditch a few pounds of tire pressure to find that sweet spot. I have the Nitto Terra Grappler MT's at 35x12. 50x18. So far a very nice tire. Little noisy bit they are MT's. Are you planning on installing the suspension yourself or having it done? I did the front with a friend, if it wasn't for air tools and a massive spring compressor, we would have not been able to do the job. Had the rear leaf pack done, and it's a good thing I did. The shop had a very hard time getting the location holes to line up, they fought the thing for 6 hours. If you live near Olympia/Seattle area, I don't mind showing you what I did… Just PM me… good luck!
