Our Ford C8000 fire engine with a Cat 3208 will usually smoke white upon taking off when "cold". It won't puff white on start up... just when it gets some throttle. After the initial take off... it won't do it anymore.
When the engine is up to operating temps... it will puff just a hint of black smoke on a take off... and a tiny stream of black smoke when crusing down the highway.
But my question is why will it smoke white on its initial take off before up to operating temps? And even after fully warmed up... if you let it idle for about 20-30 minutes it will white smoke on the initial take off again.
Are the cylinders too cool for complete combustion? I've tried Stanadyne Performance formula but it really didn't help this problem. The thermostats are working properly so I'm getting 180 temps eventually. And its not burning oil as the level never moves on the dipstick between changes. If it were burning oil... I think I could smell that. The odor of this white smoke is definately diesel fuel. Any ideas on why or how to cure? Thanks
