Heads up!
First of all, thanks for your kind words!
I really appreciate!!!
I have to bring another potential problem to your attention.
Yeah, I know sooner or later you'll gonna hate me and my problems...
It's the ECM's.
Last batch one of Doug's ECM's was Death On Arrival; DOA.
I've tried to fix it to no avail... He got burned!
This batch. THREE bad ECM's !!! I've been able to fix two of them but I'm still trying on the third.
There is a simple way to test them. It's the wait to start light.
The ECM runs a self test when the wait to start light is on.
I've build a simple "tester" so I can test the ECM's on the bench.
I test ALL ECM's when they arrive before I work on them, and then 5 more times during the process.
Obviously, the average customer can not build a tester on it's own...
How to test an ECM. Simple with your truck...
Disconnect the plug from your original ECM ( leave it in place no need to take it out) and plug in the ECM you're going to buy.
Now turn the ignition on ( Don't start the engine ) and check what the Wait To Start Engine light is doing. It HAS to work like it normally does. That means, in warm weather it has to come on for 2-3 seconds and then turn off. In colder climates it will also cycle the grid heathers and then turn off.
Very short cycling of the light, longer than normal, always on, never on, on after some time or worse flashing light are all clear signs of an ECM with hardware problems. If you're faced with such an situation please contact me so we can discuss if the purchase is worth it or not.
SO PLEASE BEFORE YOU LAY DOWN CASH FOR A USED ECM TEST IT!!!
First thing when I'll be back from the vacation I'll build a few of those "testers" for Doug, Bob... .
Having found those DOA ECM's here, faces me with an situation I don't like. Why is the ECM bad? Was it Marco that burned it while working on it? Who's responsible for the BAD ECM??????
To try to repair an ECM I have to open it anyway... .
If YOU check the ECM's before shipping, well everything is CLEAR and everybody knows why a problem does exist.
Thanks again for your PATIENCE and attention.
Marco
