SW update.
I think I've got it sorted out.
It's been a looong weekend with litlle sleep...
I've got the throttle for the early build 2001's working correctly now in my truck. Here's the last problem I still have... My truck is a '99 so it runs in limp mode with the the 2001 SW. To be 100% certain that everything is OK the SW needs to be tested in the truck(s) it belongs to. Murle, Kat you don't mind to be my guinea pigs... Don't you????
Well I'm 99. 5% sure it'll work. That's why I say " I think".
I have to say a few words to Murle,
Thanks, Thanks, Thanks... .
You've helped me big time to steer into the right direction to solve this problem!!!
So now you're supposed to:
1) Wait in front of your place for the UPS truck to show up.
2) Test your ECM in the 5 minutes after you recive it.
3) Fire the BBQ in case it does not work... . :-laf :-laf
I'll PM you the UPS TRK# later today.
Same goes for Eric 'xept #3... .
So far I have worked only on Murle's and Eric's ECM's. With what I've found out about these, I want to check all the other software versions in order to be sure that there are no more bugs hidden somewhere... I'll send them back to Doug within a couple of days. Sorry, please be patient... Thanks!
Over at DTR , Battering Ram has kindly posted his Dyno results with the CaTCHER.
http://www.dieseltruckresource.com/dev/showthread.php?s=&threadid=48807&perpage=15&pagenumber=6
I'm not a great dyno fan but since several are asking for dyno numbers, here you go... .
Let me know what you think about them.
Marco
