SO, Joe Blow has PSI problems with his 24 valve fuel system, and coughs up the $$$ for a replacement Lift Pump (LP)... BUT, to his total disgust, the NEW LP displays exactly the SAME PSI fluctuation problem the original did! It starts off fine, and delivers full PSI up around 15 PSI or so for a few seconds - THEN drops down to almost zero. It will come back up near full PSI if Joe does the WOT bit - but as soon as max PSI of about !5 or so returns, so does the erratic fluctuation.
DAMN, what could be wrong - especially with *2* different LP's - and ONE of them brand new? #@$%!
It's called C-A-V-I-T-A-T-I-O-N!
And I made up a short video to demonstrate it in action...
OK perhaps not as laboratory-like as some might insist upon - but here's a video example of cavitation - focus on the PSI in effect, not the method it was obtained - it all works out the same, whether the PSI is obtained while the pump is installed on the engine, or on a test bench...
Click here to watch Cavitation
It's worth mentioning that even with NO restriction related to clogging, kinked lines or others, these Carter pumps WILL cavitate at 15 PSI or so, it's just their nature and design - aggravated by use of diesel fuel as the liquid being pumped instead of the gasoline for which they were originally used.
In many cases. it's NOT an issue of the pump being poorly designed or defective, simply an issue of the pump being placed at the wrong location on the truck, and the wrong application - these pumps will last nearly forever if PROPERLY installed on a diesel rig, JUST AS they do on gasoline vehicles!
Even if the OEM system on our trucks are relatively free and open - the solution to cavitation is to either provide for better overall system flow, or provide a method to reduce overall system PSI to some point BELOW 15 PSI or so, such as a PSI regulator.
The pump used in my video demo has operated flawlessly on my truck for 50K miles - but the rest of my system has enough mods to not allow cavitation problems, such as relocating the LP down to the frame, back near the fuel tank - that same pump pictured will operate pretty much endlessly down at 12-13 PSI - but you can see what another 2 PSI causes to happen!
But to be totally fair where criticism of the Carter is concerned, just try to run a FASS, Holley or Walbro mounted up high on the engine like the OEM Carters are, and see how well THEY hold up over the long haul!
:-laf
