Engine/Transmission (1998.5 - 2002) Cavitation is NOT your VP-44's friend!
2nd Gen Non-Engine/Transmission Question on Thuren Track Bar
I would STRONGLY suggest you look up the definition of cavitation. It is not "pumping air" It is making small pockets of vapor in a liquid. Centrifugal pumps like water pumps, fans, and vacuum cleaners are TOTALLY different the positive displacement pumps. They do draw less amps when the fluid or air is stoped. Think about it, you are saying the pump cavitates before the relief valve opens? Why is there a reliefe valve then?
I wont waste my time with this any more. I encourage everyone to check things out for yourself.
Bob V
How about someone else than Gary take a pump other than a carter and see if it will cavitate the same as the carter.
We try this pump and that pump and get sometimes results sometimes not.
Walbro pumps seem to be the latest "thing". How about someone take a Walbro and do the same test / demo Gary did and see what happens.
Aeroquip 1000's are anothe of the "now" pumps. How about someone take a Aeroquip 1000 and do the same test / demo Gary did and see what happens.
FASS AIRDOG RASP same same.
Test the pumps FIRST, before recommending them. The only "testing" is "it works for me on my truck" which depends on how YOU drive etc. I am guilty of the "it works for me" syndrom as well. Test first, novel idea?
Bob Weis
Flow bypass valves are looking better and better.
WELL, I have little doubt that each different pump design will have it's own cavitation threshold - and gearotor pumps like the Walbro that are designed for PSI up close to 100 PSI would seem far more resistant to cavitation problems. But then, for our application, they require use of a bypass regulator valve - the SAME sort of valve that probably would prevent cavitation issues with our Carter LP's.
They're not expensive to buy - and I even built my own:
Used with my current Walbro, I am running a decently stiff 20 PSI as registered at the inlet of my VP-44...
But sure - the more test data, the better! ;) :D
As in many things in life, there are tolerance variations in manufacture - if the bypass valve spring tension falls at a PSI below cavitation threshold, all is well and rosy - and then, the viscosity of the liquid being pumped comes into play. Will syrup cavitate at a lower - or higher - PSI thru the SAME pump as would water? ;)
What liquid was the Carters originally designed to pump - and what is the typical viscosity difference between diesel fuel and gasoline?
Bob V
Shucks, I just DID - even made a video! :-laf :-laf
OK so we all have our opinions on the cavitation issue. How bout some thoughts on what MBowman asked. Inquiring minds want to know! ;)
Yeah... . :{
My second pump ran really well for about 10k. On day I shoved the clutch in to coast (slow down) for a RxR crossing that was a ways up ahead and I heard the engine stumble. So I took a look at the FP gauge.
My FP gauge was in synchronous with Gary's video doing the 15 to 5 psi thing. Occasionally it would pop back up to 15 psi and just as sporactically drop to 3 psi or zero. However, up till then I had never noticed any issues with it.
All in all, a fine talking point discussion. My hat is off to you Gary. Thank goodness, most have moved on past the Carter which is a good thing.
Jim
Bob V
+1
Like Bob says, "cavitation" is making small pockets of vapor in a liquid. A low pressure causes the liquid to turn to vapor, and then when the low pressure is removed the vapor bubble collapses on itself and creates a shock wave.
"Cavitation" does not put air in the line. Once the pressure is normalized, the vapor returns to a liquid. Air bubbles don't spontaneously appear - there needs to be a source.
So the air bubbles aren't proof of cavitation. There's something else going on here.
+1
Some of you guys are in denial of what you are seeing - and attaching WAYYyyyy to much importance on what to CALL it, and totally missing the point that it IS happening, is PREDICTABLE, and REPEATABLE!
Not just on a single pump - but on LOTS of them! ;)
OK, Call it "Fuel separation" - or "Vapor creation" - or any OTHER personal favorite you prefer - but the POINT is, it quite predictably occurs on what at this point is a pretty wide representation of individual pumps - 2 of my own, and others in THIS thread and another I have running on another board.
FORGET the name "Cavitation" if it bothers you - focus on WHAT IT DOES, and HOW TO CURE IT!
And that way is CLEARLY to SLIGHTLY reduce overall system PSI to a value slightly below 15 PSI, and enhance pump operation by methods such as reducing as many KNOWN system restrictions as possible, while doing everything reasonable to benefit system fuel flow to keep the fuel MOVING.
Personally, in my own mind, it IS fuel cavitation - on my own truck I have treated it as such, and totally AVOIDED any related problems - and all here who read this thread with an open mind and willingness to USE the provided info to their advantage can do the same if you don't get all hung up on finding fault with what you see, or putting your own NAME as to what's happening - YOUR choice! ;) :D
Gary
I think that you have hit the mark with what is going on with these pumps. I am looking for a cure to the problem as you are. I have installed idiot lights on both my trucks and had one pump fail and a dirty filter on the other truck.
What I would like to know is What happens when the pump is mounted on the frame rail? Will the point of cavitation rise to well above 15 psi? What effect will changing voltage do to the cavitation point. The motor speed is voltage sensitive and these are universal motors just like the one in a vacuum cleaner.
If you still have the setup that was in your video would you set the fuel up on the bench so that the pump would have a siphon to it and see if the results change?
Thanks for the great video
Robert
1998. 5 2500
1999 2500
low fuel pressure warning lights on both
Don't get discouraged no matter where you go there you are
I think:
1. 1 way to reduce "call it what you may (CIWYM)" is to have a good full flowing system. When the fuel gets to the VP44, what the VP44 does not take (ie does NOT go through the VP44) needs to go somewhere (like back to the tank).
2. another way to reduce CIWYM is to eliminate as many restrictions as possible anywhere in the entire fuel system.
I think Gary has already mentioned #1 & #2 many many times (see pics of the VP44 pre input fuel port bypass valve). Change the pump so the characteristics of CIWYM change (FASS, RASP, AIRDOG, etc). Look into your fuel tank (many other threads) and see the ultra restrictive hose that draws fuel out of the bottom filter that clogs up and is not cleanable unless you drop the tank, ... ... , or gut the tank filter and install inline fuel filters outside of the tank that you can clean (/replace).
BASICALLY CLEAN UP THE SCREWED UP FUEL SYSTEM "WE" SO LOVINGLY CALL "OURS" (thanks DC!). (I know about the yelling thing).
Start at the tank and work your way forward piece by piece, item by item, hose by hose, until you have addressed the ENTIRE fuel system.
AIN'T NO OTHER WAY
Those who have done it, it works really well. Those who have not done it, have a higher level of frustration than those who have.
Bob Weis
Robert
Yes, I can - and WILL do that, as well as another demo section to display "CIWYM" that is totally OUTSIDE the pump and ANY possibility of leaks or similar contributing factors - but delivers the SAME example of vapor generation/separation and foam/bubbles.
Might be a day or so, but stay tuned... ;) :D
LOL :)
CIWYM Hm... .
I am pretty sure it is CVWTMI, sorry fellas had to to that.
Jim
HOOKAYYyy - some suggestions - and a few criticisms and disagreements on "correct terminology" - the most reasonable request was for another video displaying the actual effect of raising the fuel source up at the same level, or above the pump - will it still cavitate?
Watch the first video again for reference:
Click here to watch Cavitation
THEN watch THIS new one:
Click here to watch cavitation---again
There are many Internet source discussions on what cavitation is - what causes it, and how to avoid it - here's a quote from one:
Cavitation means that cavities or bubbles are forming in the liquid that we're pumping. These cavities form at the low pressure or suction side of the pump, causing several things to happen all at once:
We experience a loss in capacity.
The pump can no longer build the same head (pressure)
The pump's efficiency drops.
The cavities form for five basic reasons and it's common practice to lump all of them into the general classification of cavitation. This is an error because we'll learn that to correct each of these conditions, we must understand why they occur and how to fix them. Here they are in no particular order :
Vaporization
Air ingestion (Not really cavitation, but has similar symptoms)
Internal recirculation
Flow turbulence
The Vane Passing Syndrome
Vaporization .
A fluid vaporizes when its pressure becomes too low, or its temperature too high. All centrifugal pumps have a required head (pressure) at the suction side of the pump to prevent this vaporization. This head requirement is supplied to us by the pump manufacturer and is calculated with the assumption that fresh water at 68 degrees Fahrenheit (Twenty degrees Centigrade) is the fluid being pumped.
Since there are losses in the piping leading from the source to the suction of the pump, we must determine the head after these losses are calculated. Another way to say this is that a Net Positive Suction Head is Required (N. P. S. H. R. ) to prevent the fluid from vaporizing.
We take the Net Positive Suction Head Available (N. P. S. H. A. ) subtract the Vapor Pressure of the product we are pumping, and this number must be equal to or greater than the Net Positive Suction Head Required.
To cure vaporization problems you must either increase the suction head, lower the fluid temperature, or decrease the N. P. S. H. Required. We shall look at each possibility:
Increase the suction head
Raise the liquid level in the tank
Raise the tank
Pressurize the tank
Place the pump in a pit
Reduce the piping losses. These losses occur for a variety of reasons that include :
The system was designed incorrectly. There are too many fittings and/or the piping is too small in diameter.
A pipe liner has collapsed.
Solids have built up on the inside of the pipe.
The suction pipe collapsed when it was run over by a heavy vehicle.
A suction strainer is clogged.
Be sure the tank vent is open and not obstructed. Vents can freeze in cold weather
Something is stuck in the pipe, It either formed there, or was left during the last time the system was opened . Maybe a check valve is broken and the seat is stuck in the pipe.
The inside of the pipe, or a fitting has corroded.
A bigger pump has been installed and the existing system has too much loss for the increased capacity.
A globe valve was used to replace a gate valve.
A heating jacket has frozen and collapsed the pipe.
A gasket is protruding into the piping.
The pump speed has increased.
Install a booster pump
See any there that might apply to our truck's fuel system? :-laf
OK - long past experience tells me that NO volume of supporting info will convince doubters or critics - so this is my last video demo - the critics can go on criticising - but hopefully SOME of the more open minded guys reading and viewing what I have provided can benefit from it, and put it to good use! ;) :D
AGAIN, the intended point is NOT what to call it - but how to AVOID it! :)
ENJOY!
I did enjoy it Gary, thanks again.
What you see at the pinch point of the second video on the suction line is what I would consider cavitation and a pretty darn good example of it. What is happening is for the same flow rate above and below your pinch point, the velocity must increase and the pressure must drop in the region of the pinch. The drop in pressure allows entrained air to come out of solution. I wonder if you could get the same thing to happen if you pulled a little vacuum on fuel.
Argh... . :)
That still does not really explain what happens in the first part of your first video. But you can trust me, I believe it happens.
FWIW
Jim
Logically, I have to agree - difficult to imagine that simply moving the fuel supply upwards about 2 feet can make so significant a difference - but it HAS, on my own truck and LOTS of others... ;)
Vaporization
This is what I have been trying to say! Some people have such a closed mind they will not listen to ANYONE!!!!!!!
Vaporization
INGESTED from WHERE?
I showed you vaporization inside a *closed* tube - WHERE was the air "ingested " from?
The sort of "ingestion" the article refers to is from air LEAKAGE in the pump or fuel path - I PURPOSELY provided a demo that totally ELIMINATED any possible source of outside leakage - did you miss it? :rolleyes:
Here it is again Bob - I made THIS section just for YOU!
http://media.putfile.com/For-Bob-V
Does the pump being mounted on the frame make priming a new fuel filter go like it is supposed to? I always have alot of trouble priming with just what the first video shows, the pump sounds as if it speeds up and as far as i can tell no fuel is pumped. However when I finaly get the system primed it peforms well on the road:confused:
Another good video Gary! This has been a good discussion and it has led me to do a little testing of my own, however... I haven't mastered the technology required to get a video out of the shop and onto the internet! That's going to be my next project!!
I totally agree with CIWYM, something is happening at 15psi. That's the bottom line!
What I tried to do is separate the relief valve from the cavitation issue. My thinking is that if I could take take the relief valve out of the equation, I could more accurately evaluate the cavitation.
Here is what I did:
My set up today did not include gages. Tomorrow's set up will include a pressure gage on the output and a vacuum gage on the input (very important, as I will explain later).
1. Duplicated Gary's set-up w/o gages. Fuel on the floor below the pump, cranked down on the output and sure enough get the sudden drop in output and pump speeds up. Cloudy fuel in the line.
2. Removed the input fitting and inserted the clear tubing into the pump so that it sealed inside the pump, past the bleed port for the relief valve. Repeated the test, cranked down on the output and sure enough got the sudden pressure drop. Only this time fuel is dumping out of the input, indicating that the pressure drop was due to the relief valve opening.
This seems to indicate that the sudden pressure drop is caused by the relief valve opening and the cloudy fuel is from the aggitation in the pump.
3. Now to take the relief valve out of the equation, I cut a short (~3/8" long) piece of clear tubing and wrapped it with electrical tape. My goal was to press this into the input and effectively seal up the bleed port for the relief valve. If it didn't seal, at least restrict the flow enough to reduce the effect of the relief valve. Put the short piece of tubing in place and put the fitting back into the inlet. Fired up the pump, cranked down on the output, no sudden pressure drop, cranked some more, pump working harder and harder. Finally stopped the flow all together with the pump still working hard. Never did experience the sudden pressure drop.
My guess is that tomorrow when I put the gage on the output, I will see that with the relief valve sealed off, I will get higher than 15 psi without the drop in pressure.
This test leads me to believe that what Gary demonstrated in his first video is really the relief valve opening at 15 psi.
So Greg... how do you explain the second video? INQUIRING MINDS WANT TO KNOW!
Here is my theory... it all has to do with pressure drop across the pump. This is why my test tomorrow will include a pressure/vaccum gage on the inlet. In Gary's first video he was sucking fuel off the floor up to the pump and then generating 15 psi outlet pressure. That means that the top of the ball in the relief valve in the inlet of the pump is actually experiencing vacuum equal to the amount required to lift the fuel from the floor to the pump. When you combine that with the 15 psi outlet pressure pushing up on the ball from below, you have a situation where the relief valve will open easier.
So what about the second video... what was different? Placement of the fuel tank. What did this do?
Now the fuel is actually a little above the level of the pump so it is flowing into the pump with a little pressure behind it due to gravity. Now, think about how this affects the ball in the relief valve in the inlet of the pump. Instead of having a little vacuum pulling up on it, there is a little pressure pushing down on it. That means it is going to be a little harder to push open, which means in this configuration, you will need more than the demonstrated outlet pressure of 15 psi to open it, just as Gary demonstrated.
I couldn't figure out for the life of me why moving the pump to the rail would help the situation if the pump always cavitates at 15 psi and drops the pressure. But now after seeing Gary's second video and having to think through how the relief valve reacts to the pressure differential across the pump, it makes perfect sense!
In Gary's first video the pressure differential is greater, therefore the relief valve opens at a lower pressure. In the second video, the pressure differential is lower, therefore the relief valve opens at a higher pressure. Higher pressure than the pump will generate with the truck idling, meaning not more sudden pressure drop due to relief valve opening. This is a good thing!
I would be interested to know what would have happened if Gary had kept cranking on the clamp until near zero flow?
Now I am convinced that moving the pump down closer to, or below the level of the fuel is a good idea... especially if you stay with the OEM fuel pump! I would say by the same logic any pump will do better down there. Hey... isn't that what Gary said?
I do want to throw another little twist into the debate and it came from my own test today. I would submit that what you are seeing in the clear tube when you clamp down on it is the fuel going from laminar flow to turbulent flow. Fluid will flow very smoothly up to a certain velocity, but when it speeds up too much, it breaks up, loses those nice flow lines and becomes turbulent. As the clamp tightens up, it decreases the area that the fluid is flowing through. The only way to flow the same amount of fuel through a smaller opening is for it to go faster. That's what you are seeing in the tube as the fuel speeds up at the pinch point and breaks up into cloudy, turbulent flow. A little ways past the pinch point the fuel slows back down, goes back to the smooth laminar flow, but still carries the residue or cloudiness from breaking up at the high velocity.
Respectfully submitted.
Greg
Greg
I sure wouldn't argue with any of that - and thanks for taking time to dig up and provide more info - takes more work than the armchair critics know, doesn't it! ;)
Main point in my last demo is - it's NOT "air ingestion" - there's no source for it to be ingested from - turbulent vaporization seems lots more logical...
Thanks!
