If the pump was Caveatting why did the motor speed up?
Robert
Good discussion, thanks for the comment. It is not my aim to argumentive just for the sake of it, but the one thought sticking in my mind is "It is airbound". Why would it get airbound?
My thoughts:
It is hard for me to tell if the pump RPM goes higher or it just gets noisier. Depending upon a what type of DC motor it is, it could noticeably speed up when load is dropped from it. A vacuum cleaner is a good and poor example of this, but ussually uses an AC motor. The only true illustration of load on the motor would be amp draw or flow rate, providing nothing else internal is going wrong. Maybe Gary could do a two bucket pump (or some such) test also if the mood strikes him to check flow rate.
In reference, a pump will not ussually cavitate much when it is airbound, nor will it pump at all or very well. In the first example on the video IMO Gary illustrates the behavior of a pump very similiar to one becoming airbound or as BobV tried to explain something else is going wrong.
A pump cavitating can still pump very well.
The second example in Gary's video IMO is a good example of cavitation and what I expected to see happen before I watched the video. Hence my question, making me wonder what really is going on in the first part of the video, because I am unsure.
A vane type pump is not all that complex and as some one stated above, not that far from a centrifical type pump in many aspects in this application. It will have characteristics of a positive displacement pump as well as a centrifical type pump.
In the trueist sense a vane pump, as well as any positive displacement pump, will pump a set volume of liquid each revolution
irregardless of the discharge pressure depending upon the displacement of the pump. It should only pump less than that volume if it is cavitating. Because it will pump to any (elevated) pressure is the reason the discharge pressure must be controlled.
So... .
If the internal bypass
was opening and
sticking wide open (or close to it), it would do so probably at a set maximum pressure. This pressure should be where it was designed to open and control pressure below that value. But is something going wrong?
In my mind, the way that the pressure goes to 15 psi then pops down almost instantly could be a very good example of this very thing happening. The discharge pressure drops because, the pump is sucking the fuel right back to it own suction. The pump itself is at maximum load, but no much fuel is headed towards the VP44.
I don't know for sure;
Sorry for the novel;
Jim
