Udaloy said:I don't believe that's true. A single antenna is omni-directional. Meaning it transmits in all directions equally. If you run one antenna on either side of the truck, the RF waves hit each other, and cause the propagation to change to a fore and aft bias (elliptical). Holding all other factors the same, this setup would give you "further" transmit/receive boundaries for the desired directions while traveling in a vehicle.
The antenna will use the vehicle also, let me explane it to you.
The single antenna is installed on the rear of the vehicle thus the strongest projection is forward due to the mass of the metal in the vehicle. If you were to install the antenna on the front fender you would get a stronger antenna direction to the rear of the vehicle,and with a antenna on both sides of the vehicle it becomes bi directional. The SWR meter ( I own the HP 5000 by Aries meters), is used to tune your c/b and antenna(s). There are laws that need to be met when installing a antenna. The most important is antenna cable length it has to be of a correct length between the antenna and the c/b and never under 3 feet and always measure your cable in 3 foot length's. If your c/b is 10 feet away from your antenna install 12 feet of cable this is the surest way to get a correct or close to SWR.
During the last 2 days I have been installing a Gallexy DX 979 C/B and a Magnaforce 350 amp in my 2001 TJ, along with a 5' firestick 2 this combo will let me get yelled at by every park ranger in California about turning down the power. I know that the amp only put's out 150w RMS but thats 400w PEP.
