CB mount/ any good ones?
Airbullydog hood
Rancho front leveling kit
I had a Y2K. I put my CB under the dash beneath the steering column. I didn't like it there because it was only inches from my feet (and the potential for my feet to get tangled in the wires if they ever came loose). It was also difficult to see the #&%$ thing.
I read a thread a while ago (while I was non-registered browser) about a couple of custom mounts for the RAM. Can anyone help me. One in particular was someone hanging it from the ceiling (I used to drive trucks, and that's where it goes!!), but I have the travel computer there.
Any ideas or links would be greatly appreciated.
I am very impressed with this site and the broad knowledge base. I hope to gain a lot, but hope to help out where I can as well.
Shane Oler
'01 2500 4X4, ETH/6 speed, Pyro (pre-turbo)and Boost Pillar mount, Dark Garnet/Camel, 20K Reese 5er hitch
Other: '70 Olds Vista Cruiser 455 (future resto project)
30' Sandpiper 5er Super Slide bunkhouse(about 10k lbs. )
[This message has been edited by SOLER (edited 02-09-2001). ]
Soler, I mounted mine on brackets under the center seat. I know it is not real handy, but I wanted it out of the way and there is no good place on the dash. I don't do much channel cruzin so it works fine for me. TDR member Michael Brolin has a truck like yours and he has a neat mount vertically in front on the center seat. You might drop him a note at MBrolin103@aol.com, or he might be able to post a picture of it.
Ron
96 4x2 2500 Garnet/Driftwood Auto,3. 54,K&N filter,Cobra radio 93 TT Terry, '84 VW Rabbit diesel,
Reply to CB mount, I have a 99 3500 quad cab with buckets etc. , I made up a large bracket approx. 12inches x12 inches as the truck isnt here i cant give you the exact measurements,Its an L bracket mounted in the center in front of the small seat between the buckets with The lower part of the L facing to the rear and bolted it to the floor I have installed a Cobra CB and VHF on the bracket,It looks great and I have acess to the mikes when traveling. When I leave the truck I just drape a towel over the seats and radios to keep them out of sight. Hope it helps.
Dittos on Brolin! All the good things you hear about his design is the truth. To see a few pics of one installed hit the link in the sig file below. Only problem with trying to see the mount is that when its installed you don't see it. Bad for pictures but great otherwise.
Darren
2001. 5 2500 4X4 SLT, ETH/DEE, Amsoil Bypass Filtration, Mag-Hytec w/Amsoil, Walker 21468, Passenger Side Grab Handle That DC No Longer Installs as of 7-00, Michael Brolin CB Mount, 14K@013101, ICQ: 103247365, IM: xxtreme223
I have a manual trans. I mounted it where the little storage bin is behind the shifter. The bin is two piece plastic; front side which IS the dash and has an oval hole, and rear side which forms the pocket. I took of the rear side, and the face of my forward-firing Uniden sits in the oval hole in the dash. It is right below the factory radio. I had to make a special bracket, but it looks good.
Well I got the CB changed from wifes car in to the diesel. I mounted it in the center of the hump in the floor in front of front seat. I fabricated a bracket that is bolted to the floor and then bolted to the CB bracket. I had interior paint left over from gauge installation and painted the brackets agate looks OK. Mounted the antenna to my fiberglass top on the forward rt side. I used a white whip RV and Boat antenna that does not require a ground. I got it at radio shack. Looks OK. Whats the best power source to use for the CB thats all I have left to do.
Thanks in advance for any help you can offer.
Rich
20yr Mopar Parts Manager,"June of 2000" 2001 quad cab,2wd,auto,354 LSD rear axle,Raven Magnum 8' cap. Mag Hitech trans pan. Isspro gauges Apillar mount. Amsoil air filter.
wait till ya see mine
jc whitney has a overhead metal color matched shelf that uses same screws as visors
i mounted a ham radio in the center of it
works grt,ran many wires up pillar post
still have 2 radios on dash on 1 st gen
i pilled the ash tray and found metal under
it 2 mt to,bill
1993 w350 ex cab, banks,nv 4500 in
open exaust, pw Injectors are in. Big rig flaps,tach in,. Its loud and goes ok, for a 93,Ham radio Call KK6dm
has ability to communicate any where in the world. Headliner shelf
5 antenna's
I've been very happy with the CB mount I purchased from fellow TDR member Mike Brolin. #ad
Anyone know brolin's address so that I can send him a check quickly. I emailed him but he has yet to reply.
2001 ETH SWB Black Sport, Blue Box, HX-40, 4" Exhaust, DD III's, RE-0880, ATS Manifold, Muth Signal Mirrors (way cool!) Too MUCH Stereo, Clifford Avant-Guard 4 w/ Remote Start, 2" leveling kit, Grizzly Nerf Bars, Pathfinder 315's, Ram Grill Guard, BLACK magic hellas, Dual firesticks, and one loud, annoying PA
Since Brolin is not making the CB mounts anymore, would anyone want to try to fabricate one of these mounts themselves or send me a diagram of one so that I can try my hand at one of these. Thanks in advance.
Ditto for me too!
Kevin MacGranor
2001. 5 D2500 QC SLT 4X4,Auto 295/75r16 BFG AT's, Century Cap, Bedrug. , Alpine Head & Amps w/ Boston Acoustic speakers & JL Audio Stealthbox center cushion Sub.
I have a JL stealth box sub in my center seat. (as seen in Mactruck's sig) Because of the plastic seat instead of the foam I was able to mount my cb right to the front of the center seat. I thought of using the cubby behind the stick but it was a messy fit for my cb.
Hey, if any of you guys with Brolin's mount want to get rid of your CB, or know anyone who does, give me a hollar and I'll buy it from you.
Take a look at the Cobra 75WXST. It can be mounted under the seat cause all the controls are on the mike.
I too have my eye on that Cobra with everything in the Mic... . Seen it in Camping World Catalogue. Under $100. The base unit is tiny! Half the size of a pack of Cigarettes and mounts anywhere, hidden under the dash is best.
Wonderful how electronics has changed!
I'm now searching for the best antenna... .
2001. 5 2500 SLT+, QC/LB 4x4, ETH, 6spd, 3:54 LSD, camper/tow equip. , NV241HD, Bright Silver, Snug Top, Ispro w/3 pod pillar w/tweeter, Pyro, Boost & Mag Hytec cover w/temp guage, "Plain Wrap" (no decals or emblems)
