CEL codes 0071 and 0514
06 Engine Parts
Need to bomb to beat 2nd gen
The last 5 days I have had a check engine (Check gauges light) on and I checked the codes and found 0071 and 0514. I found TSB 18-005-06 but the build date on the engine indicates it is not applicable because my engine was built 02/06/06 and the cut off fot the TSB is 01/31/06 any ideas as to the problem?
if you have an 06 the p0514 code is battery temperature sensor rationality and p0071 code is ambient air temperature sensor performance,ambient/battery temperature sensor performance,inlet air temperature sensor rationality... . its no big deal mine throws those codes every now and again it is when the air temp sensor and the battery temp sensor don't read the same. there is a reflash to fix it
This makes sense being the problem started after I began plugging in the Mopar battery blankets and block heater. I guess that there would be a difference in the temp recorded by the two sensors.
Thanks!
I did setup a profile but it is not sowing. Must have done something wrong.
I will check it.
