WW -- best gets you into the same debate that auto transmission owners have been having (i. e. , DTT or ATS or Goerend or you get the idea).
What can a novice do? Depends how big a novice and what tools are available. I've changed gears, installed lockers, replaced axles, etc. , on Toyotas, which allow the whole 3rd member to be pulled (similar to a ford 9-inch), but have not done any such on a Dana... which requires a case spreader to get the carrier out. Without guidance I'm a little reluctant to tackle... not that it can't be done.
If you were open in the rear your could easily do a lockright or quiklock since the carrier wouldn't have to be removed... for any other locker you need to pull the carrier making it more challenging. If you have a case spreader and you know how to use it you just might be good to go w/ an install. If you know anyone that's changed gears on a dana axle and they're willing to help you'll be even further ahead.
Air vs Electric vs Automatic has been a locker debate on more sites than just this one... from my perspective there is no BEST one, just one that will make the owner the happiest. Air (i. e. , ARB) & automatics (i. e. , Detroit) have both been around a while and have strong followings. Electric are newer. My only experience with air anything was air shocks and that was less than positive as I kept having problems w/ seals and air retention. Some ARB owners will say this is a constant problem... others will say if you install and maintain it properly you'll never have a problem... potentially you won't know until you flip the switch and it doesn't engage. In order for air lockers to work you have to add and air compressor. For electric to work you need electric... and well... we all have that on our truks already. Have not heard much feedback for owners on the electric lockers yet. For either you will be making a hole of some type to get the air/electric in to the diff. Is it worth it? If selectable lockers are desired that's one of the prices you pay.
Pricing example (pulled from a 4wd mag for a D60):
Detroit Locker: $513 ($552 for a D70)
ARB (Air): $665 ($776 for a D70) plus $195 for an ARB compressor
Detroit Electac: starting at $796
Eaton Elockers seem to be under $600 for most applications.
MAYBE... you get what you pay for... but then again maybe NOT. I run a lockright in a toyota landcruiser and have heard a lot of people call them junk, but I've never broken one (axle shaft yes, welder spider gears yes, lockright never!).
If you want to see how they work, look on the respective makers websites (ARB, Detroit Electrak, Eaton)... sorry don't have the websites handy, but I'm sure a google search can get you there. If you can't find them report and I'll look when I remember and have leisure time.
If you want to actually talk w/ someone knowledgable call Randy's or Reider's or even West Coast Differentials... they are all generally helpful and have a lot more knowledge on the subject than I ever hope to have. Not all D60, 70, 80s are the same... Dodge has some odd aspects that might limit your selection.
Not sure why Uncle would say plate pinning is not for a Novice... doesn't sound any more technically challenging that replacing a carrier. Be curious to see Uncle's reasoning.
jm
jm
