Changed differential fluid for first time!
Debadged and rebadged...What do ya think?
Air Lift Road Tamer Discontinued?
Well, today marks the first time I changed my differential fluid on my '06 3500 Ram dually. It wasn't bad. A few points to remember for all of you novices (like me):
For the 06 3500 Ram dually with the AA 11. 5 rear (limited slip) and the AA 10. 5 front.
You will need a 13mm socket with some varied extensions. My socket was a six sided 1/4 inch. I suggest getting a larger 13mm socket (5/8 at least).
Get 8 quarts of fluid (I used Royal purple 75w-90 full synthetic) + MOPAR's limited slip additive.
I bought the Jay's EZ Funnel from Geno's. Save your money. I'm sure it is a fine product, but all I used was the clear plastic tube that was included as an extension. I used the extension as a slip on for the Royal Purple nozzle on the quart. Worked great and no mess. I couldn't get all of the oil out any other way.
I'm not a mechanic, and I don't think swimming in this fluid is safe. I use vinyl gloves (think dental office). Kept the hands clean and no funky fluids to worry about.
Mark all the bolt holes and fill bolts with alignment paint. Might seem like overkill, but it will ease the final "adjustment" at the end. Simply tighten and when the lines match up... you're done.
The front diff is a pain in the neck. Literally! Bars in the way, no room and just plain hard. This is where all those extensions on your socket come into play.
Get a socket adaptor for your handheld drill. I only recommend this to the type of drills that have clutches. I turned my clutch WAY down and simply used it to take the bolts out and put them back in to snug. I always put the bolts in by hand so as to make sure they weren't cross threaded and then used the drill to make them snug. Then use the socket to finish the job.
I took a lot of people's advise and used MOPAR's limited slip in my rear diff. I know people will say you don't need it, but a lot of people are having issues and why not solve the problem in the beginning instead of having to put it in later and be all upset about it.
I used two oil pans to catch the old fluid. I also used BRAKE CLEAN to clean out the metal flakes on the magnet and also on the interior diff itself (with cover off). Make the purchase of shop rags. They had no lint to worry about and they do a bang up job of cleaning the interior of the cover. You'll use a few of these rags and then you can just pitch them in the trash. I have been married a while Gents, don't think about putting good rags to clean with this synthetic stuff in your wife's washer. Not a good idea!
Dispose of the old fluid at a oil change place or one that accepts outside used oil. Remember, the environment is our friend. You dump this stuff on my acreage and I'd chase you down too!
Overall, a few hours work. Saved lots of dollars and have a deep satisfaction of a very good job completed. Don't forget the Motrin for the neck for those of us getting a little older.
Hope it all helps!
I installed a PML cover on my 06, now all I have to do is pull one drain plug and my diff fluid changes take 15 minutes... :-laf I don't care what the inside of the differential looks like, if it fails thats what warranty is for. BTW, I used the AMSOIL 75/110 which has the LS additive already in it and is a great fluid if you plan to pull with your rig...
Dodge has changed their tune on LS additive. Didn't use to say you needed it, but some have reported chatter and the LS a dditive takes care of it. THey have no idea why since their are no clutches in the AMerican axle so now Dodge makes a fluid with the LS already in it. .
1/2" socket won't fit? 13mm and 1/2" are pretty darn near the same size, 13mm being just a hair larger.
I use my impact gun to get the bolts off. Quick and easy. I do the same with transmission pans. One of these days I need to pickup a 3/8" cordless impact.
Nitrile gloves is what your talking about. I use them all the time at home and work. About $7 for a good sized box off the tool truck.
When changing the differential, transmission and transfer case fluids, should the truck be brought up to operating temperature before fluid change or should it be done when cool? Sorry for the basic question. I know engine oil is supposed to be warm, but wasn’t sure about the other fluids.
Doesn't really matter. If you do as most people do and take the time to clean off the magnet and the rest of the diff cover, the fluid has already drained. This assumes that you are doing this at a comfortable ambient temperature also. Once you pull the cover(s) off, it doesn't take long to drain in warm or cold temps.
I used Royal Purple also, but it already has the LS additive in it so I don't know why the OP used more. I'm going to be changing mine next week. I've been running 85-140 in my rear diff. Time to change it back to 75-90. I don't tow enough.
Getting ready to do mine here within the next week or so. Did you have to purchase a new gasket. And what other brands can you use for diff fluid. I was going to put mobil 1 75w 90 in there but i may change my mind if there are folks that have used it and didnt like it. Also to add the the viscosity, I dont tow as much.
I use the AMSOIL 75w140. Dodge changed their specs, my dealership told me at the time I purchased my truck to use 75w140 when dioing the change. They have both the Mopar and AMSOIL fluid in stock, they sell more AMSOIL than Mopar according to my dealer.
The gasket is re-usable. I have the MagHytec covers on after the first change. Nice and easy to change fluids and check them. I noticed the difference using the AMSOIL immediately, no more hop at startout with/without a load.
CD
I am having great luck with the Amsoil 75-90. It was a simple job. I used a socket u-joint for the front which made getting around all of that stuff in the way much easier. I did however break one of the bolts when putting the rear back on. It must have been defective because it broke right off when I was tightening. I used a snap on torque wrench and torqued to spec so I know I didn't overstress the bolt. The new bolt was 2 bucks from Dodge, but way cheaper then having them do it.
Wholly crap youre supposed to change that stuff :confused: :eek: who knew?? :-laf Yeah shame on me and the worst of it all would be is that I have a diff cover that I bought back in muncie ... as in thunder in muncie LOL
