charging trailer batteries
Generator?
Reese TowBeast and the 3rd Gen installation
hey guy's I'm in the process of setting my truck up to pull the new camper and was wonder what size fuse is used to charge your trailer batteries?
Joe
I believe mine has a 40 amp fuse which carries the trailer brakes and lights/charging. You want to set up the trailer brakes on an auto reset breaker and the charging line really depends on the wire size you use. #10 wire is good for 50 amps. bg
If your trailer battery is depleated when you plug in to the truck, the momentary inrush current which lasts for only a few seconds can be enough to trip a 30A fuse.
An auto reset breaker solves this and is a great solution. Available at most auto parts stores.
Rog
I have the charge wire wired in to it's own space off of a fuse block and use a relay to control it. I was thinking about using a 5 or 10 amp fuse for a battery charge,I'm afraid I will over charge the battery using a 30 or 40 amp
Joe
The 05's have a 15 amp charging line in the (six flat one round) factory trailer plug for charging while you tow I believe the 1st gen trucks are aswell. The shore power plug will either be a 30 or 50 amp breaker, depending how big your trailer is and how many A/C units ETC you have.
Mac :cool:
In 1992 when I rigged up the battery charge line on my new D350 CTD to tow my 5th wheel, I used 8 gauge wiring directly from the truck's battery, both positive and negative, to the 7-way RV receptacle in the truck bed. On the positive line, I installed a 40 amp circuit breaker near the battery and a relay similar to this one http://www.tekonsha.com/product3.html
to prevent the truck's cranking battery from discharging while parked. The relay was activated when the ignition was turned On. Do not use a starter type relay as they aren't designed for continuous duty. I never had any problems with this system, no dead cranking battery, and the batteries in the 5th wheel were always charged up after a few hours of towing the trailer.
In theory, the all batteries should equalize, but in reality the trailer battery remains at a slightly lower charge level because of its distance from the truck's alternator.
Bill
