38flathead
after a long bout of tring to figure out my loud chatter on my 96 12v that i've had since new, and yes i know that it is solid lift and its a diesel and yes they make a lot of noise(but good noise) the problem is solved. It turns out that my vaccum pump was indeed bad. motor still ran great but chatterd after removing the pump I found it extremely tight and missing about 6 teeth on drive gear had to remove timing cover to retreive broke pieces but was successfull. recommend stethescope . On this truck I had installed repair kit that was recommended thur club about 5 years ago. Don't know what caused problem but back to the normal chatter and loving it. Thanks for all your sugestions. spool up and be save Jim Kuhman
