Was looking at the throttle pedal this morning and took a couple foot long piece of broom handle and glued a piece of 1/4 wood dowel a couple inches long sticking out the side of one end. If you look at the area above where the throttle pedal is hinged, you will see that the dowel will fit into V area between the pedal and its mounting bracket. RPM can be set at any level you want. I then put a short piece of dowel in the other end that sticks up when the "SNOKING Custom Fast Idler" is held in the correct position to activate.
PS, used my wooden window scraper/snow brush at first, then thought, "OK, I want fast idle while I scrape the windows and brush off the snow!" Dumb and Dumber!!!!!!!!!!!! Oh well the 1/4 hole in the scrape will just fill with snow, maybe I will glue a plug in it, after all I have had it for about 20 years.
SNOKING
