... i said 3 but meant 362
OK... Cummins fault 362 is equivalent to OBDII DTC P0253, which is "FUEL INJECTION PUMP FUEL VALVE OPEN CIRCUIT. " This is a VP44 internal fault meaning low current or no current has been detected at the VP44's internal fuel control valve. The following items can cause this:
1. A faulty fuel injection pump relay located in the PDC (Power Distribution Center), which is on the driver's fender under the hood. Solution: Replace the relay.
2. Or it can simply be caused by low battery voltage, typically when cranking the engine. Solution: Charge the batteries and replace if needed.
3. Or there could be something wrong inside the VP44. Solution: Replace the VP44.
I'd start by clearing the trouble codes with a code scanner, drive the truck again, and check to see which ones come back. If the P0253 shows up again, replace the fuel injection pump relay, clear the trouble code again, and see of it comes back. If it does again, then pull the fuel injection pump relay so the engine won't start, and check the battery voltage while cranking the engine. This will set one or more trouble codes which you'll need to clear after the test. If the battery has at least 8 volts during cranking, then the VP44 must have the problem and will need to be replaced.
To troubleshoot that P0382 DTC (the INTAKE AIR HEATER RELAY #2 CONTROL CIRCUIT), follow these steps until you find the cause:
Step 1
Ignition Off
Disconnect the Ground Connector at Heater Relay #2.
With an ohmmeter, measure the Ground Circuit to ground.
Is the resistance below 5. 0 ohms?
If NOT, repair the open Ground Circuit.
Step 2
Ignition Off
Disconnect the Intake Air Heater Relay #2 Control Circuit.
Disconnect the ECM Connector.
Using an ohmmeter, measure between the Intake Air Heater Relay #2 Control Circuit and ground.
If YES, repair the Intake Air Heater Relay #2 Control Circuit for a short to ground.
Step 3
Ignition Off
Connect one end of a jumper wire to the open relay terminal and briefly tap the other end of the jumper wire to Battery (+) terminal.
Did the Intake Air Heater Relay click?
If NO, replace the Intake Air Heater Relay #2.
Step 4
Ignition Off
Using an ohmmeter, measure the resistance of the Intake Air Heater Relay #2 Control Circuit from the ECM to the Relay.
If NO, repair the open Intake Air Heater Relay #2 Control Circuit.
Step 5
Since no other causes remain, the ECM may be at fault and needs replacement.
Let us know how things work out.
Best regards,
John L.
