Couple of days ago the check engine light stayed on after starting but noticed no change in performance, etc. Later it went off for the rest of the day. Today, it stayed on again but still noticed no problem until I came out from a restaurant and the engine would turn over fine but wouldn't start. Tried 3 or 4 more times with same result. Checked the fuse in my FASS fuel system since I didn't hear it run prior to starting as I normally do. It was fine. Opened the drain cap on the FASS filter and drained off a small amount of fuel. Tried again and the engine fired right up. Everything seemed normal except for the check engine light being on for several miles then the engine missed a few times and the tachometer started jumping around, dropping to zero and then would jump back up to normal.
Any suggestions from any of you fine folks of TDR would be greatly appreciated. Thanks. BJesik.
