Check engine light onCA trucks withDTTvb&tc?
94 standard cab 4X4...weight?
I need best way to run co-ax for C/B Radio.
Have all you guys with CA trucks that have Bills vb& tc installed had engine check light come on . If so, any solutions or will it be like the old vcr syndrome & put some black electrical tape over the display. I,m getting mine installed in a couple of weeks& would like not to have to look at the light if poss when it inevitively comes on.
2001,2500 q-cab,auto 4x4,4. 10 anti-slip rearend. All options except leather seats. Line-x bed & tool box. Slide-in -removable rack,BFG 295,s ,Fender flares. Westin nerf bars,billet grill & fog inserts. Rancho,9000,s,Isspro gauges,1994 2500 4x4,12 valve,5 speed, bone stock for now.
knock on wood--the dreaded light has not come on--I don't know why--my truck is a '99--I did install the resistor first about 3-4 days before I installed the vb and them about a week later the tc went in--I don't know if this had anything to do with it or not--chris
Treeman, If there is any problem Bill Kondolay will fix it no black tape needed.
Is this a joke?
What is the cause?
Bob
[This message has been edited by Bob Wagner (edited 03-06-2001). ]
Bob ,I think it is only the California trucks that are tripping the CE lights ,something to do with BS emmision laws we are subject to. I,ve heard Bill is working on a fix for this .
I have DTT's VB & TC in my California truck. I don't know if his VB will set a code or not. When I had my BD stuff it did and the fix was a simple one. It is a 100 ohm 1/4 watt resistor. Do a search if you have the problem or Bill will know for sure. It's no big deal.
Arlan
Guys, my understanding from Bill K. is it is the 2001 CA trucks that are doing it. He is working on a solution. I believe it has to do with the minimal drop in RPM from lockup. Normal is a few hundred RPM's, and only 75 with his TC.
Fred Swanson
Co-Owner
Canyon State Components, LLC
www.canyonstatecomponents.com
'00 QC,SB,4x4,Auto,3. 54 w/LSD,Trailer Package, Tow Package, DTT's VB & TC
75 rpm drop at lockup? I don't think so.
I have the DTT setup. RPM drop at lockup is
200rpm's with the 91% TC.
Yep... ... my tach moves about 1/2 of a slash mark when going into lockup. I figure around 75 rpm's..... this is with the 91% TC also.
Gary... ... .
01' 2500 - QC/SB, ISB w/Auto, 4X4, 3. 54 LSD, Solid White - Westin Bars, A. R. E. Cap, Bug/Vent Sheilds, K&N Re-0880 Air Filter(Scotty), Autometer Ultralites Boost/EGT/Trans/Fuel, Custom 4" Exhaust, AutoTransformed DTT TC & VB, DD III's and DD Torque Module, HX-35 Turbo.
[*]SETDR Member
[*]TU Member
[*]NRA Member
Mine drops about 75 rpm mt and about 150 towing.
2K, 2500, Quad, SB, 4x4, 3:54LSD, A/T, reese 15k 5th slider, EASLEY BULL BAR, WESTIN NERFS, TA's, 9000's, stealth DD2's, Bully Dog Boost & elbow, ISSPRO pyro, boost & transmission, Turbo Lifesaver, JARDINE 4", DTT VB,TC,TC SAVER and AUX COOLER, PAC BRAKE, MAG HYTECH TP& DC, AFE filter onboard. Taylor Wing and Gear Vendors on order
pullee #1 26' Arctic Fox 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA-LIFE, VFW-LIFE, SoCSA-LIFE, SASS
[This message has been edited by JNutter (edited 03-07-2001). ]
Here's a question for you. .
How/why did you choose 91%. How do I know what % to buy?
98. 5' 24v 2500 Auto/3. 54 4x4 SB QC 285-75-16's on Alcoa's. Everything but leather. PIAA 1200's, AMSOIL dual filter relocation system, Smittybuilt Stainless Steel Nerfs, Rhino Liner(Junk), K&N air filter(For Sale)15 year AMSOIL dealer. Time permitting, Soon to include Ultra-lite Pyro,0-50lbs boost, Trans temp in the pillar. Rancho 9000's with in cab adjustment.
it has something to do with the CA emissions , the stock TC has about a 400 rpm drop when going into lockup , the DTT is anywhere from 75 to 150 ... some says 200 , since the marks are 125rpm each are you sure on that 200 ? ... anyway something in the CA computer is looking for that big rpm drop , if its doesn't see it ,it is assuming the TC is slipping or not locking up and sets a code ,bill is working on a fix .
deezal man , 91% is the minimum TC and the 93% is for the hardcore BOMBers , there should be someone near you with one in their ram , 91 i'll assume , get together with the person and go for a ride , i am installing a 93% this weekend , i have the 91 , i will probably go back to the 91 so i am told , it is a bit harsh and this is my commuter vehicle , though i do drag race it on occasion #ad
I have not heard of this problem. When I first saw this post I thought you referring to the check engine light that occurs from excess voltage to the governor pressure solinoid. My rpm drops are as stated above and I do not get a check engine light.
cscpusher and Mopar-muscle are correct.
Deezal Man, you might want to check out my post in the "Which DTT TC did you guys get" thread (24 Valve Forum).
BTW, I have 50 rpm drop when going into lockup.
[This message has been edited by John (edited 03-09-2001). ]
Treeman,
I thought about asking you to delete your post, Ive thought about not answering this post. How do I answer this post without tipping my hand and help my competitors. When we first introduced our tc system we looked at several things that were causing these transmissions and tc’s to fail.
We were not interested in building our tc the same as our competitors, milling the OEM stator was not even an option for us. We knew it was in effective, caused torque multiplication loss and power transfer loss. While we admit it would be very profitable to use this method as it was the accepted industry practice, we knew it was damaging to the transmission, as it generated too much heat and relied too much on the tc clutch to transfer the power of the Cummins.
I realize that there are Ram owners out there that totally disagree with me as they have conditioned by the industry to believe that their tc clutch can handle the power of the Cummins. Everyone uses more clutch lining, including our company, everybody increases the transmission line pressures including us.
My point being, just because a tc is advertised to have more clutch lining, and a VB has higher line pressures do not be fooled into thinking that by simply adding a mystery switch or torque loc your transmission is now prepared to take on the power of the Cummins. It that were true , there would not still be so many tc and transmission failures.
You guys can believe me or not. All you have to do is look at the 6speed and 5 speed guys , they have 4 times the clutch surface area. And they can slip their clutches with just a basic power upgrade.
So think about it, what exactly are you expecting from your automatic torque converter clutch.
Now most people have been conditioned to accept that the automatic transmission is weak and it is prone to failure. It is funny though if you think how much punishment the automatic transmission is expected to take as compared to the standard. The automatic transmission is expected to shift under full throttle
Without taking your foot off the throttle, and if it breaks you say what a piece of junk this transmission is.
If you try doing that with a standard transmission and it breaks, you call the driver an idiot, doesn’t he know he is supposed to take his foot off the throttle and use the clutch and ease back into the throttle. He should know that you shouldn’t power shift the transmission.
When a guy in a standard is in 5th or 6th gear and is putting around and then goes from light throttle, straight to full throttle, and his clutch slips because of it, you call the driver an idiot , doesn’t he know you are supposed to down shift otherwise the clutch will slip.
Now on an automatic, when a guy is in od, uses a mystery switch or a torque loc to force the tc to stay locked up and in od, and then he goes from light throttle to full throttle, and the tc clutch or transmission starts to slip, you say the automatic transmission is a piece of junk.
Now are you guys seeing my point here.
The automatic transmission is not at fault, the expectations from this transmission are un realistic.
When we engineered our transmission components and our torque converter, we had to consider all of the above. All of our components are designed to un-loc the torque converter clutch under heavy or full throttle conditions. Our tc is engineered to perform most of its functions in fluid coupling .
As far as we are concerned the only time we to have the tc clutch engage is for fuel economy when cruising down the highway and exhaust brake applications.
Our tc transfers 40% more power in fluid coupling than ANY OTHER tc on the market. So we DON’T NEED forced lock up in our system.
Now Chrysler in their great wisdom have programmed their pcm to monitor the tc clutch application. The computer sends a signal down to the tc clutch solenoid to activate the tc clutch and then monitors the tach to look for an rpm drop indicating the lock up cycle has been completed.
It is looking for a minimum of 200 rpm drop. If it fails to see that 200 rpm drop 3 times in a row, it sets off a 1740 code or a 0741 code, or a 1744 code. While this is not a big deal as it does not put the vehicle into limp mode, on California emissions trucks, it sets off a check engine light.
While it does not affect the drivability of the truck, the code is meant to tell you your tc clutch is not working or slipping and you need to have it fixed. As you guys are driving the trucks know, that is not true, the tc is working just fine.
With the design of our tc, it does not always produce a 200 rpm drop, the rpm drop can vary depending on hp, gear ratio, & vehicle combined weight. Some of our guys out there have as little as a 50rpm drop when going into lock up.
The solution is quite simple, we merely have to lie to the computer so it can see what it need to see. We are field-testing the system at the present time.
Bill Kondolay
Diesel Transmission Technology
[This message has been edited by Bill Kondolay (edited 03-10-2001). ]
Bill,
If I were just to have your ValveBody installed but keep my stock Torque Convertor
because of lack of finances(IRS #ad
),Would you recommend this temporary upgrade? I really plan on getting your TC later and have Kustom Truck in Yuba City do the work.
Thanks, Bob
Y2K Black 3500 ISB 4x4, 4:10 LSD,Auto,QC,SLT Laramie,"EZ", LB, Polished Stull Billet Grill & Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges,Rancho 9000's set at '1',Diamond Plated Tool Box, OEM U. R. Bedliner + other stuff.
Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
Bill,
A better post I have not seen! If my 98. 5 were setting a code for that reason I would do the electrial tape thing if you couldn't come up with a fix. No way would I drive my truck without the DTT VB & TC. Ya know, instead of the electrical tape, a smiley face would work.
Arlan
98. 5 ISB QC 3500 4X4 3. 54, PowerMax1, DTT TC & VB, TY303 225/70/19. 5's on Rickson Wheels, 275 Injectors, Mag-Hytec Transmission Pan/Differential Cover, 9000 LB Warn Winch, Ultra Board Running Boards, Westach Combo Boost/EGT Transmission Temperature & Fuel Pressure gauges, Pac Brake, 2-lo kit, CB, GPS, Rancho 9000's, ATS exhaust manifold, JRE 4" exhaust with muffler and resonator. Lifetime NRA Member
Bill , aplogies to you if i caused any problems with my post. It was not my intention to slight your great product or bring any negative attention to it in any way,just merely trying to find out what other guys had done to hide the light if it came on, as there,s some pretty creative members out there when it comes to problem solving . Thanks for an excellent post on educating myself & everyone else on the working relationship of your tc & our trucks. Greatly looking forward to getting it in my truck. Ian
1994 2500,4X4,12 valve,bone stock for now
Robbyram,
You can add a vb first,whenever budget is a factor, the vb takes priority over the tc.
Here is why , the vb is what protects the transmission and the tc against slippage, we do not sell a tc unless the customer ups his line pressures. Either with a shift kit or a replacement vb.
Treeman,
Dont ever apologise for asking questions,i for one do not believe in blind loyalty. The guys on this site by their questions are changing this industry.
Customers seem to be doing more research about what is best for their applications.
Best research is to ask questions from guys actually using the products. It help you the customer to seperate hype and marketing from actual performance.
It is i who must apologize if i made you feel in any way uncomfortable for asking.
I was just being lazy as i knew it would take me a while to compose the response without assisting the reverse engineering process.
Bill Kondolay
I installed a DTT VB & TC about a month ago. I am extremely satisfied with the result. I highly recommend Bill's product, and am willing to give anyone a ride who lives in the South Bay...
99' 2500 4X4 Auto
