This morning the 'Check Engine" light came on. So I pulled over when I could and checked all gauges, voltmeter was showing app. 8+volts. (This has happened before) Shutdown engine and checked under the hood, nothing obvious. Started up again, voltmeter 8+ volts, ran up to speed and voltmeter did not go to 14 volts. A few minutes later "Check Engine' light again! Pulled over, shut down and waited a few minutes, started up and voltmeter up to 14+ volts and no 'Check Engine' light. Anyone have any ideas what could not be working correctly? Relays?
Thanks,
Crabman
Thanks,
Crabman
