Is there a best way to determine if the control arm bushings are shot? I looked under the truck at the bushings but I cannot tell if the bushings are cracked or not.
When I replaced the control arm bushings in my 97 4X4 the ones from Energy Suspension had me re-use the bushing steel casing/housing. I had to heat up the control arm (removed from truck) till the bushing sizzled and shot out the the arm. Then I cleaned it up and inserted the ploy bushings in with the supplied silicone grease. They just slid in.My bad, I had a total brain fart. I got A arms and control arms confused, looks like you could get the control arms off pretty easy and give it a go yourself, but they may be pressed in which will make it a tough task without a press.
If you search on their web site (as I did when I did mine last year) it will tell (in a side note I believe that was hard to find) you must re-use the shells and it will tell you to heat up the end of the control arm till they pop out. They can fly about 5 feet so watch out. I used a propane torch and it took 3 minutes or so till the rubber began to sizzle and then it would fly out like a missle... cool!Kaptchinskie said:I am leaning towards replacing them as that should almost complete the front end rebuild (ball joints only thing left). I looked at energy suspensions and their cross reference chart states that I would have to reuse a metal sleeve currently in the bushings. Can I press these type out if I am going to reuse this sleeve?
