Is pulling #1 injector and sticking something in the hole to watch piston movement the best or only way?
I found JLeonards puller pic and can make it easy enough. Read in the FSM on the procecure for injector removal and install. They mention discarding a washer on the injector and replacing it. Is this necessary and where could I get some?
I want to check TDC and set the pump timing. Bought a dial in dicator setup for the pump and borrowed a barring tool.
Andy
Andy
