Chirping noise from Dash?
ford steering box on my 06
Difference between Diesel and Gas Speedo?
I'm hoping someone has had this problem and they were able to fix it. I have an annoying chirping noise that seems to come from the dash area directly in front of the driver. It only happens when I hit jarring type bumps(washboard roads are the worst) I can't identify the exact location as it is not always consistent but when it happens it is very annoying. I've tried pressing on pieces and parts of the dash, windshield and instrument cluster as well as the steering wheel and shift column but nothing makes it stop. Dealer thinks I'm crazy! Please Help!
I had that in my '87 Ramcharger and it was the glove box door, I could never get it to go away. If it is in front of the driver it might be the bazel.
Kevin
I have it too. Comes and goes. Sometimes it's the Viper Pillar trim piece... . Grab handle. It may also be the cowling rubbing the windshield on the outside.
The 2nd Gen trucks had a TSB out for instrument panel creaks. The repair is a quite involved (a nightmare from what I've read).
My truck has it. My father-in-law's 2001 has it also.
I just turn up the radio and ignore it... it's not loud... just annoying.
Best regards,
John L.
NO: 23-19-00
SUBJECT: Instrument Panel Creak
DATE: May 5, 2000
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 23-08-99, DATED MAR. 5, 1999, WHICH SHOULD BE REMOVED FROM YOUR FILES AND NOTED IN THE 1999 TECHNICAL SERVICE BULLETIN MANUAL (PUBLICATION NO. 81-699-00004). THE REVISION ADDS ADDITIONAL MODEL YEARS AND ARE HIGHLIGHTED WITH **ASTERISKS. **
OVERVIEW:
This bulletin involves loosening the instrument panel and providing additional clearance between the A-pillar inner panel and dash panel.
SYMPTOM/CONDITION:
A creak or squeak may be present near the left and/or right side(s) of the instrument panel. The noise is caused by the sheet metal joint between the A-pillar and the dash panel plenum lower rubbing together.
DIAGNOSIS:
Drive the vehicle slowly over a bump that will allow the body to twist, such as a driveway approach, to verify the condition.
NOTE: IN SOME CASES, THIS CREAK CAN BE PRODUCED BY HAVING AN ASSISTANT STAND ON THE FRONT BUMPER ON THE SAME SIDE AS THE SQUEAK/CREAK AND BOUNCING THE VEHICLE UP AND DOWN WHILE YOU ARE LISTENING FOR THE CREAK INSIDE THE CAB.
If an instrument panel squeak/creak can be heard coming from the A-pillar area, open the hood of the vehicle and inspect the 3-T welds (cowl panel welds) (Figure 1) located aft of the hood hinge and inside of the fender. If the 3-T welds appear cracked or rusted, refer to the appropriate Ram Truck Service Manual Group 23 for sheet metal weld information.
NOTE: IT MAY BE NECESSARY TO HAVE AN ASSISTANT STAND ON THE FRONT BUMPER ON THE SAME SIDE AS THE SQUEAK/CREAK AND BOUNCE THE VEHICLE UP AND DOWN WHILE YOU ARE LISTENING FOR THE CREAK. IF THE SQUEAK/CREAK CAN BE HEARD, SPRAY PENETRATING LUBRICANT ON THE 3-T WELDS. IF THE SQUEAK/CREAK IS ELIMINATED, REFER TO THE APPROPRIATE RAM TRUCK SERVICE MANUAL GROUP 23 FOR SHEET METAL WELD INFORMATION.
If the condition is present and the 3-T welds are not causing the squeak/creak, perform the Repair Procedure.
PARTS REQUIRED:
Qty Part No. Description
AR (1) NPN Body Seam Sealant, 3M - 08302 (or equivalent)
REPAIR PROCEDURE:
Record the radio station presets.
Disconnect and isolate the battery negative cable.
Remove the left and right cowl side trim.
Remove the knee blocker beneath the steering column.
Disconnect the shift indicator cable.
Loosen the lower instrument panel attaching bolts.
Remove the steering column support nuts.
Remove the left and/or right A-Pillar molding as necessary.
Remove the five instrument panel attaching screws holding the instrument panel to the dash panel.
Remove the two screws that secure the trim cover to the Airbag Control Module (ACM) (Figure 2).
Remove the two instrument panel to ACM mounting bracket-retaining nuts (Figure 3).
Roll the top of the instrument panel away from the body as shown in Figure 4.
Peel down a portion of the door-to-A-pillar weatherstrip from the cab (Figure 4).
If the repair is to be performed on the right side of the vehicle, peel back the dash silencer pad and wiring harness.
Scrape away the body seam caulk between the A-pillar inner panel and the plenum lower panel (Figure 5).
Using a flat chisel no more than 1/4 in. thick, drive the chisel between the A-pillar inner panel and the plenum lower end. Start the chisel 1 in. below the joint line between the plenum lower and the gusset/cowl bar and drive the chisel horizontally to a depth of 6 - 10 in. (Figure 6)
NOTE: ALTHOUGH YOU MAY VISUALLY SEE A LARGE GAP BETWEEN THE A-PILLAR INNER PANEL AND THE PLENUM LOWER END, THE GAP MUST BE AT LEAST 1/4 IN. WIDE THE ENTIRE 6 - 10 INCH DEPTH.
Repeat Step 16 by starting the chisel in the same place but drive the chisel upward at a 30 degree angle.
If necessary, perform Steps 14 through 17 to the other end of the cowl panel.
Verify the repair by having an assistant stand on the front bumper on the same side as the squeak/creak and bouncing the vehicle up and down while you are listening for the creak inside the cab.
Perform Steps 16 and 17 until the squeak/creak has been repaired.
Reseal the area with body seam caulk (3M 08302 or equivalent) to prevent water leaks.
Reattach the door-to-A-pillar weatherstrip seal(s).
Re-assemble the instrument panel to the body.
Install the two Instrument panel to ACM mounting bracket-retaining nuts. Tighten the nuts to 14 N• m (125 in. lbs. ).
Install the two screws that secure the trim cover to the Airbag Control Module (ACM). Tighten the screws to 2. 2 N• m (20 in. lbs. ).
Install the steering column.
Install the knee blocker.
Install the left and right side cowl trim.
Reconnect the battery negative cable.
Reset the clock and reprogram the radio station presets identified in Step 1.
POLICY:
Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Op. No. Description Time
23-50-01-94 Provide Clearance Between Instrument PanelSupport Joint And Cowl Side Panel (One Side) 1. 0 Hrs.
23-50-02-92 Provide Clearance Between Instrument PanelSupport Joint And Cowl Side Panel (Both Sides) 1. 2 Hrs.
FAILURE CODE:
Code Description
XX Service Adjustment
Dealer found it!!!!
Thanks to everyone who replied. Took the truck into the dealer for the H34 recall and told them not to call until the chirping noise was fixed. 3 days later I get the call to pick it up. They removed the steering column and dash and found two bolts that were loose that attach the dash to the brackets and two bolts that were loose that attached the dash to the firewall. Drove it home and no more chirping! Glad I didn't have to do it or pay for it!
