Here's a few pictures with Dodgezilla 14cm turbo in twins. B2 on bottom Very happy with them so far hope to dyno this weekend. Check out more pictures at www.powerbypoole.com
Jim Fulmer said:Did you just give up working on Mustangs, there are allot more of them than trucks?
Jim
Bob Wagner said:what a cheap shotOllee does first class installations and fab work.
OPoole said:Retorque is done a litte test drive tonight. 10psi boost launch killed the tires into OD will dyno friday.
OPoole said:Dynoed friday was hoping for 620hp or better but didn't make it. It was 94degs humidity was 85% inside the truck was 100deg. At best 592hp 1266tq. this was on a Dyno-jet 248c. Will try again when it cool downs and will have to upgrade the fuel pump the single carter 15psi can't support the Mach 6s.
