Clearance Lights
Instrument panel center bezel lights
Tires again
I have a leak on my '04 dually, thinking it's the clearance lamps. I sometimes have water dripping from pass. side visor clip. Anyone know where to find the seals for these lamps for cheaper than 12 bucks each? Dealer wants 11. 97 each for them.
I looked at RockAuto and 1A Auto and no luck.
Thanks.
SOLER
Soler,
Possibly you could consider making your own gaskets?
All you would need is the old gasket as a pattern, an X-ACTO knife, and a sheet of foam gasket material.
You can buy 1/8" thick Neoprene foam sheeting from McMaster-Carr for only $5. 71 per lineal foot (57" wide sheet). One lineal foot would sure make a lot of clearance light gaskets!
Good luck,
John L.
I found the plastic yellow covers cracked on two of my cab lights and went ahead and replaced all of them with the Recon LED blacked out ones.
Mine leaked under warranty also took it back to be fixed and dealership just put clear silcone under the the lights. I wasn't happy about it but they dont leak for now.
