Hello Folks, I need some help!
My wife's 98 Blazer has recently developed an occassional clunk in the front end. It does it only in 4 wheel drive and at various speeds. It is not binding as it does it on slippery snowy roads. It is just a "clunk" sound every now and then - not continuous.
I found no worn ball joints, no problem with u-joints or boots on front axles, no bad or tight u-joints on the front driveshaft. No other obvious problems.
I've narrowed it down to two ideas:
Could the front axle disconnect be disconnecting and reconnecting causing the clunk?
Could the chain in the transfer case be worn out and binding or jumping teeth?
The clunk seems to only happen under load or steady, level travel. It does not happen while coasting downhill.
Thank you.
Blake
Thank you.
Blake
