How do you tell if this noise is U joints, tie rod ends,ball joints, or other. Please help clunking noise is getting worse.
cluncking when? when rolling ? hitting a bump?...
Check the shocks for any side to side play. One of mine had play and it sounded like the front end was going to fall off.
Make sure they are torked down correctly. My problem started shortly after I installed new shocks. The passenger side needed to be retighted.
Be sure you check your sway bar bushing links and and sway bar frame mounting bushings. my sway bar frame bushings were wore and it made a god awful clunking when going down a bumpy road. I put some urethane ones in no more noise... .
btw not to side step you like the h2 rims? did you get chrome or the aluminum/grayish silver?
