Clutch, Exhaust options...Just need help
Governor Spring Kit Observations
HELP!! New TPS, problems still there
Hey everyone.
My name is Michael, and im new to the TRD club. I have some questions. I am really in need of a clutch. I wanted to see what you all thought about clutches. I want a clutch that will hold up, and not slip... but i dont want to spend 1000$. Centerforce or Luk Progold, South Bend? I have been told good and bad things about all three. I am going to get either the DDI's or the 275 hp injectors, but thats the end of me bombing. I think :). Have any of you ever ran dual pipes out the back? I have thought about it, and if i got the 4inch down pipe, ran two 2 inch pipes off of that. . then out the back? Will it work? Is it worth the time? Let me know if anyone has tried this... or if anyone knows who sell this setup. Thanks everyone. Keep trucking.
99 4x4 ext cab. TST Pm3, 5 spd, 3. 55's, k&n filter. 33. 5 12. 50 16. 5 Firestones, Flares, Rims, Tool box, bed rail covers, Light Driftwood.
Hi Michael. Welcome to the TDR. I'll give you my opinions on your needs. I have the Centerforce Dual Friction. It has held up for 45,000 miles with the few mods I have (check sig. ). If you are even THINKING of more mods in the future, spend the extra money now and buy a better clutch.
On the exhaust, the single 4" downpipe splitting off into two smaller pipes works fine. That's how mine is set up, except I have all 3". My recommendation would be something larger than 2". Problem is that 3" is hard to fit around the spare tire. I had to remove mine. 2 1/2" might fit fine.
98. 5 3500 QC 4x4, Driftwood/Mist Grey, 5 spd, 3. 54, 19. 5 Alcoa's, Ranchhand bumpers, DeeZee toolbox, "Physcotty Air", TST PowerMax2, VA, 275's, Autometer Gauges, Centerforce clutch, Upgraded fuel lines (JRE and Aeroquip), MagHytec Diff Cover, PacBrake, Cowl Induction Hood
Mike,
I have dual 3" all the way and my spire tire is still in and operational. you need to find a good pipe bender and installer.
Jeff Allan
31D 81199
2000, 3500,4x4, 355 gears Laramie SLT, BD valve Body, BD Torgue Convertor, BD pressureLoc,#14cm wastgate turbo housing, powermax 3 adjustable, stage 3 injectors, custom dual 3" exhaust with dual 4" barrel tubes behind rear tires. Trailmaster SSV shocks, ISSPRO Turbo boost, EGT gauges in piler, K&N air filter, bushwacker fender flares, black nerf bars, Let the BOMBing begin
