Actually, a "dual disc" clutch is what was described above with flywheel , clutch disc, floater plate, clutch disc, pressure plate. A "dual friction" clutch is simply a clutch that has two different friction materials on the opposite sides of the clutch disc. An example of this would be the Southbend Conofe. It has organic material on one side and feramic on the other. This way you get the holding power of the iron and the drive-ability of the organic. A compromise between full feramic and full organic. The centerforce is not a dual disc clutch, but as you said a dual friction unit, i do not know what friction materials they are using on the clutch disc. Do yourself a favor and at least call Peter at southbend. He is a wealth of knowledge and will answer all your questions gladly. As mentioned above also, some members have been less than satisfied with the performance of the centerforce products in our rigs. And yes, high load applications can be very hard on clutches, especially when you add good power, small fast spooling turbos and a heavy foot. If you are going to stay where you are at power wise, you will probably be very pleased with an all organic unit. If you foresee any more power mixed with some heavy trailer towing you may want something like the OFE. I have one in my 98 12valve that i tow 15k 5er with and it is a nice unit.
