I have a question that I need advice on before I go drop a bundle of money on a clutch that I may not need. When I first start out in the morning I do so in neutral. When I go into first gear or reverse with the clutch engaged, the shift requires a bit of effort, but when it finally goes into gear, there is no grinding or clunking. Doesn't this mean that the clutch is engaged and free from the input shaft? If this is the case, then I really don't have a clutch problem do I? Could the problem be with the synchros? or somewhere else in the transmission? I want to be sure about this before I spend the big bucks on a clutch only to find out I have another problem in the transmission. The transmission is still covered under warranty. I guess that's what I want to be clear on before I make this move. Thanks for bearing with me on this subject.
John
John
