clutch
any of you coming 08252001 to the sacramento MOPAR race track
trans shift points
Does any one make a clutch that will hold up in truckpulls but that is a good street drivable clutch as well? I have tried the Mcleod and the southbend with mixed results. Both clutches will slip on a good track and both vibrate on engagement. With only minor upgrades this should not be a problem. By the way my truck is a 01 6-speed 2500 4X4. Any help would be great. Thanks
A member, Joe Donnelly, also has his hand in the clutch business. You might try contacting him.
Have you called Peter and talked to him with specifics of what you are looking for? He may have some recommendations...
If you are looking for more options you could change the flywheel to a older style (12"?) and change to the smaller input shaft then there are many more to try.
