I was towing aprox 8k on flat ground the other day at 70 mph and out of the blue there was a thud noise which sounded like it came from the transmission. The CEL came on at that time and the P2146 code showed. I turned the edge back to stock and towed 200 miles across a mountain pass with not a problem. The CEL turned off the following day but still showes the code. Does anyone know if this is a common code to be caused by the edge or what may cause this code? I know the code means "Fuel Injector Group 1 Supply Voltage Circuit". Any help would be appreciated.
