bigceltic
Just curious.
In post #11 Timd32 attached a pdf with some good places to look. I didn't see anywhere in this thread where the EMC connectors were physically checked. Did you disconnect C2 form the ECM and look at/clean/reset the related pins and cavities, including finding/inspecting G114 (ground)? Also, there are two ECM related splices identified in the schematic.
Power: Voltage checks to the power pins.
Continuity: (battery positive terminal disconnected*) Ohm checks from respective C2 pins to B+ (Battery terminals) and respective C2 pins to ground should verify continuity.
- * Never do an ohm check from a power source to ground. Excitement factor elevates. Magic smoke leaks from meter/fuse and/or meter wires.
I did not. I will do so this week. Thanks for the reminder.
