Engine/Transmission (1998.5 - 2002) code po121 and truck wont shut off
2nd Gen Non-Engine/Transmission Tire Life ?
2nd Gen Non-Engine/Transmission Vacuum boost, no ps/pb
I was going down the road lost TPS and pulled truck over. Shut ignition off but truck is still running. Use scanner to verify that I had no TPS. Someone told me that the injection pump in shorting out. Only happens after you drive it for a hour. Any suggestions what it might be.
If you turned the key off, you have bigger issues than a TPS or VP shorting out. IIRC, Key off should kill all power to everything but the starter, and ECM/PCM.
This is what I found in my 2002 FSM:
P0121=accelerator pedal position sensor signal voltage too low
P0121=throttle position sensor voltage does not agree with MAP sensor
P0122=throttle position sensor voltage too low
P0122=accelerator pedal position sensor signal voltage too low
says all of these should trigger a MIL on the cluster
hope this helps.
Phil
So yes
The TPS is the same as the APPS
Call TIMBO His APPS is way beefer and Cheaper than Dodge BY far
Do a search on TIMBO on the Forum
Great Guy to deal with and a great Product
Chris
When it won't shut off try pulling the "fuel pump" relay in the relay panel aft of the battery and see if that will shut it off.
Here's the link to Timbo. Home
Works better than OEM, much cheaper. Be sure to use the torch to loosen the idle screw. I didn't at first and broke a torx socket off.
