Engine/Transmission (1998.5 - 2002) codes
Engine/Transmission (1994 - 1998) Oil pan gasket
I have installed an ez a few months ago and i am well pleased, but I keep reading about setting off codes. Will just an ez set codes if so how will I know?
The EZ is a pretty good product. Most of the time it will not set a code. When ever you set a code, 9 out of 10 times it will cause the check engine light to come on. If it would happen to set a code, they are pretty easy to clear. Most of the time you just have to disconnect your battery for 30 minutes.
