If you are only interested in the front see what can be done, checking shock length then decide about the rear. Depending on what load carrying ability you need, you can adjust the rear. For instance, if you don't haul or tow, just junk the helper spring, or junk it and add bags, or junk it and add part of a mini-pack. With the leafs in back you can "custom stack" easily. Since you are in uncharted waters in regards to shock length, your gonna have to measure and figure yourself.
